1955 Olds special bolt
Old March 27th, 2015, 06:52 AM
Olds Scott's Avatar
Is there a special bolt that holds down the intake manifold and spark plug wire harness and if so where can I get one?
Olds Scott is offline
Old March 27th, 2015, 07:20 AM
fuxl's Avatar
Should just be a 3/8-16 bolt.
fuxl is offline
Old March 31st, 2015, 02:26 PM
Olds Scott's Avatar
Took pictures of the condition mentioned.
Old March 31st, 2015, 07:26 PM
72 Olds CS
RetroRanger's Avatar
is it supposed to be a bolt w a stud on top (IDK what theyre called) but the a bodies have a bolt like that on the heads like this pic (but not exactly like that)
RetroRanger is offline
Old March 31st, 2015, 07:54 PM
Proud Viet Nam Veteran
redoldsman's Avatar
You can use some 3/8" all thread and use two nuts. If you lived close you could come by and I would cut some off and give you. You can get it at Home Depot.
redoldsman is offline
Old March 31st, 2015, 08:45 PM
Olds Scott's Avatar
The IDK bolt looks good but would like to have the 3/8 on the bottom and the 5/16 on top. Sure would like to find the stock bolt but top end of engine was torn down when I got the car. If no luck finding it might have to weld 5/16 piece of all thread on 3/8 bolt
Old April 1st, 2015, 02:15 PM
Mark57's Avatar
You could drill and tap the 3/8 bolt head for 5/16 thread and make a 5/16 stud to thread in and lock it in with red lock tight. I would not drill very far into the head of the bolt to make sure you don't degrade the bolt strength.
Mark
Mark57 is offline
Old April 1st, 2015, 04:56 PM
Olds Scott's Avatar
Thanks Mark57, that is also a good option to the problem.
Rocketbrian
September 18th, 2014 07:02 PM
mpolds
February 11th, 2014 02:20 PM
NorTown Olds
Paint
April 6th, 2013 06:46 AM
charlierogers
January 28th, 2012 08:09 AM
f-85
January 11th, 2009 09:31 AM
Quick Reply: 1955 Olds special bolt
