1955 Olds 4 barrel adjust with vaccum guage
Old January 31st, 2017, 02:18 PM
Olds Scott's Avatar
Where can I hook up a temporary guage on my 324 for adjusting my Rochester 4GC mixture screws? My ears aren't what they used to be.
Olds Scott is offline
Old January 31st, 2017, 02:28 PM
Any available full manifold vacuum port.
oldcutlass is offline
Old January 31st, 2017, 04:36 PM
Olds Scott's Avatar
Thanks oldcutlass but which one? Distributor vacuum advance port, vacuum wiper port.
Old January 31st, 2017, 06:50 PM
I'm not 100% familiar with your year engine. Is the wiper port from the manifold or vacuum pump? Is there an available port on the manifold itself? Is the vacuum advance manifold vacuum.
Old January 31st, 2017, 07:10 PM
Olds Scott's Avatar
Not sure if it is a constant vacuum source.
Old January 31st, 2017, 09:09 PM
Ozzie's Avatar
The vacuum advance is ported; so that's not so good.
The wiper vacuum motor feeds through the pump's booster; so that's not so good.
On the 4GC there is a full vacuum tap at the rear of the throttle body which connects to the pump's vacuum booster. On mine there is a "T" fitting; one side goes to the vacuum booster on the fuel pump; the other end has a plug which could be used for a vacuum gauge.
The only problem I'm having is remembering if that "T" fitting was always there from the start or if I added it somewhere over the life of the car to get some pure manifold vacuum to do exactly what you are proposing. Anyway look at the back of the throttle body part of the 4GC. Right in the center of the back there is a "tap" (1/4" NPT???) If there is no "T" fitting (the factory may have used an elbow), you could add a "T" which would make your task easier in the future.
Ozzie is offline
Old February 1st, 2017, 05:56 AM
You can also set idle mixture screws with a tachometer. Set them for maximum idle speed.
Olds64 is offline
Old February 1st, 2017, 07:40 AM
Olds Scott's Avatar
Thank you Ozzie and Olds64. Running a PVC valve in line with out road draft tube and with power brake vacuum hose. Would have to find a fitting to run a third vacuum outlet. Will try the tach idea first.
Old February 1st, 2017, 09:34 AM
74 2.8L Capri
DFitz's Avatar
The tach works fine. I used a tach on my '55 2-barrel. I would however not adjust to max idle. Initial adjust to max idle, then back off about 1/4 turn. You don't really want the idle mixture that lean. It will hesitate and stumble.
As an alternative, if you can smell gas in the exhaust, it might be just about right!
DFitz is offline
Beau Dirt
December 27th, 2021 03:02 PM
72delta88
October 10th, 2016 07:47 AM
63 F85 Cutlass
February 8th, 2015 03:20 PM
69oldsdelta88armyvet
April 27th, 2014 01:02 PM
Finn5033
April 10th, 2012 09:23 AM
Quick Reply: 1955 Olds 4 barrel adjust with vaccum guage
