1955 grille/bumper trim problems
Old May 22nd, 2017, 09:55 AM
Sock Thing's Avatar
Hi I was hoping you all may be able to help me figure out which of these two pieces of bumper trim is the correct one. They both are very similar but not quite the same. The rusty one came with the car when I bought it but was not on the car at the time. The shiny one I bought just recently. But when I put them side by side there are some differences. The shiny one is thicker in some places as I try to show in the pictures it is also heavier than the rusty one and has a number stamped on the back R-6232-1 and another one below that 4292. The rusty one has no such numbers. I just want to figure out which figure out which of the two is correct for a 1955 Oldsmobile 98. Thanks for any help you all can provide.
Sock Thing is offline
Old May 22nd, 2017, 10:20 AM
Tedd Thompson's Avatar
Wow. I've never seen that much difference between grill parts and a I thought all 55 front grill parts were the same,regular, supers and ninety eights.I am wondering if one is a 54 and not a 55. How does it look against the far side?
Perhaps someone with a Hollander could look up that number and see if it matches your year and car.... Just a thought.... Tedd
Tedd Thompson is offline
Old May 22nd, 2017, 11:41 AM
jozw30's Avatar
I would think only one of those will match up with the hood lip? That's a large difference.....
jozw30 is offline
Old May 23rd, 2017, 07:37 AM
Sock Thing's Avatar
Hi again thanks for the responses. Yeah I was surprised by the difference as well. Unfortunately I don't have the hood lip to compare it against. But if one of you guys who have a 55 could measure that top rib of the part on yours I could compare the measurement to mine and see which of my parts is closer. I would really appreciate it thanks.
Old May 23rd, 2017, 07:56 AM
jozw30's Avatar
My hood lip measures 0.94" wide at the end on that top surface.
jozw30 is offline
Old May 23rd, 2017, 09:53 AM
Sock Thing's Avatar
Thank you very much jozw30 for measuring that. Unfortunately that means that the rusty one must be correct as it measured 0.943''. While the shiny one measures 1.172''. I was kind of hoping that if one had to be wrong it would be the one in worse shape. But at least now I know. Now I just have to figure out what the shiny one is off of thanks again.
Old May 23rd, 2017, 10:02 AM
jozw30's Avatar
Maybe they changed those parts mid year or something? Can't imagine what other model that larger size would be for?
jozw30 is offline
Old May 31st, 2017, 02:14 PM
Russ P in MD's Avatar
Had a chance to measure originals off an S88, and NOS pieces last weekend. All were the same and under 1.00 inch. Only guess my dad had was that maybe the 98s were wider? Couldn't think of any other car that had that exact same shape piece of trim.
Russ P in MD is offline
Old May 31st, 2017, 06:51 PM
98's should be the same as all the rest of the 88 series. Have you looked at a 56 the hood lip is different (thinner) on a 56 maybe that is the answer..... Just a thought.... Tedd
chasman414
June 25th, 2020 07:05 AM
dz442
May 14th, 2019 07:45 AM
Olds Dad
April 7th, 2011 08:57 AM
tailfins
February 11th, 2011 10:57 AM
toyktdlgh
15
May 14th, 2008 06:52 AM
Quick Reply: 1955 grille/bumper trim problems
