power steering high pressure hose
Old June 22nd, 2020, 03:05 PM
king_doodle's Avatar
Hello Olds gents,
I have had a heckuva time finding a replacement power steering high pressure hose for my 1966 Olds Dynamic 88. I've been sent 2 incorrect hoses by different sources. Parts companies seem to think that Gates #352410 is the correct hose, but it's not. Does anybody know the correct part number? The connection on one end is straight and ever so slightly angled on the other end.
Thanks in advance,
Craig
king_doodle is offline
Old June 22nd, 2020, 03:13 PM
69HO43's Avatar
If all else fails and you can't locate the proper hose part number, check around your area for an industrial hose shop. Tell them what you want to do, and bet dime to donuts they can make you a brand new crimped hose using your original fittings. It'll bolt right in. Last time I did it, the cost wasn't out of hand. Quite reasonable, actually.
69HO43 is offline
Old June 22nd, 2020, 03:15 PM
That's a good idea, 69HO43. Thanks for thinking of it.
Old June 22nd, 2020, 03:22 PM
I think I found it. The correct part appears to be Gates #362120. This is listed as a Buick part, but apparently was used on Olds as well. I believe it would work for the Delta 88 and Dynamic 88 both.
Old June 22nd, 2020, 03:37 PM
69HO43's Avatar
Great news. It appears it just may be the ticket.
69HO43 is offline
RandyS
May 13th, 2020 12:01 PM
Apollo
July 14th, 2016 04:16 PM
billwaldo
February 18th, 2015 12:47 PM
DRXOLDS
May 1st, 2011 09:51 AM
KQQLCAT
June 4th, 2009 07:23 AM
Quick Reply: power steering high pressure hose
