1979 Hurst Olds Dual Gate Shifter Installation
Old May 31st, 2018, 05:24 AM
carlsongb's Avatar
Cool 1979 Hurst Olds Dual Gate Shifter Installation
Hi all,
Just bought a dual gate Hurst shifter from a 1979 Hurst Olds and want to install it in my 1980 Olds 442 W-30.
I have looked online and cannot seem to find a schematic on how the 1979 dual gate shifter is installed. Does anyone have any tips and or diagrams that will help in my installation?
Thank you for your time,
Glen
carlsongb is offline
Old November 13th, 2022, 04:20 PM
Gerald Nickels's Avatar
Isnt that the same shifter used in 70-72 Hurst just different brackets ?
Gerald Nickels is offline
Old December 17th, 2022, 09:03 PM
Hoffa65's Avatar
no. different cable routing and length
Hoffa65 is offline
Old December 18th, 2022, 09:54 AM
TRFREE's Avatar
I believe the shift cable is different also.
TRFREE is offline
Old December 18th, 2022, 11:20 AM
69HO43's Avatar
And the way it mounts. Sort of. Brackets are different and you'll have to modify the console section a bit.
If you got the brackets and the top plate, you're miles ahead. Yes, the cable is different, but from what I've heard (I've never done it personally) the brackets line up with the regular shifter mounts. I could be wrong on that, however.
Note in the console pic below there's a small section of the console that doesn't get cut for the bolt to attach to the front bracket on the driver side. Same for the RH side, but it's sorta out of the way.
69HO43 is offline
69442murph
March 27th, 2022 06:20 AM
mrolds69
April 10th, 2018 07:58 PM
69442
October 24th, 2015 06:26 AM
fast67vellen2o
July 26th, 2015 11:48 AM
69OLDSCUTCONV
June 26th, 2011 07:18 AM
Quick Reply: 1979 Hurst Olds Dual Gate Shifter Installation
