trans making whining noise ?
Old June 9th, 2009, 03:07 AM
ls442's Avatar
I have a 67 442 with a 1971 455 and 350 trans with a stall speed converter it drives fine when i put it in gear drive or rev it makes a load whin give it more gas it go's away no noise in park or new fluid is clean + leavel is it the stall converter thanks ?
ls442 is offline
Old July 11th, 2009, 06:50 PM
csstrux's Avatar
Moved to appropriate forum.
csstrux is offline
Old July 11th, 2009, 07:18 PM
svnt442's Avatar
Torque conver took a dump. Happened to me last year with under 1000 miles on the trans. I'm STILL fighting with the shop that did the work to reimburse me. It happened before I moved and he said it was in the engine. I took him at his word even thought I knew better. I moved and had it replaced for $500. I'm gonna see him in a couple weeks. He doesn't know I'm coming. I'll get my money one way or another.
Check your fluid for metal shavings on the stick. It's probabaly the sprag or one of the impellers hitting.
svnt442 is offline
Old July 12th, 2009, 01:29 PM
jimjr's Avatar
Possible cause of tranny whine...
My 67 Cutlass w/ 2speed Jetaway tranny and variable vane torque converter whines at low to part throttle (that is, when the kick-down switch works like it should!). The whine goes away as the kick-down switch shuts off at a higher throttle demand. I'm not saying that this is the problem, but I'm only offering it as a "shot in the dark". Keep us posted on the results and good luck! Jim
jimjr is offline
68Dreams
April 26th, 2013 07:16 PM
Charles Ludwick
28
March 7th, 2012 04:45 PM
Railguy
December 12th, 2011 06:38 AM
hunter
November 18th, 2011 11:45 AM
davisjd77
Alero
July 14th, 2009 04:02 AM
Quick Reply: trans making whining noise ?
