TH400 leaking from lower coolant line
Old September 22nd, 2016, 05:00 PM
1969 Oldsmobile Cutlass S
RustyOlds's Avatar
Another day another leak. Today's leak is on the lower transmission coolant line. It only leaks while the car is running and leaks about a drop every minute. I've heard online it could be an o-ring of sorts? Anyone have any ideas on this? Also is thread sealer a viable option on this? Thanks!
RustyOlds is offline
Old September 22nd, 2016, 05:16 PM
That should be a flare fitting, so no o-ring or sealant. There could be a nick or burr on one of the mating surfaces.
Fun71 is online now
Old September 22nd, 2016, 07:13 PM
You might try taking the joint apart cleaning and reassembling. Do not use any sealer or tape on the threads as that is not a sealing surface, the end of the flared line is.
oldcutlass is online now
Old September 23rd, 2016, 01:39 PM
BlackGold's Avatar
Don't just clean, inspect as well. When I bought my car the previous owner had installed copper lines. It leaked about a drip a minute, like yours. I thought I was smart to tighten the nut an eighth turn. When I started it up again, there was a geiser. Turns out the flare on the copper line was split; tightening made it worse, not better. Hope you have better luck. And if you have copper lines, replace them with steel as the factory intended.
BlackGold is offline
Old September 23rd, 2016, 10:04 PM
65vistacruiser's Avatar
Only late model Fords use an O-ring with an inverted flare.
Someone may have made single flares on your lines as opposed to double inverted flares. The double flare is thicker, no sealer needed.
65vistacruiser is offline
Jono
October 3rd, 2015 07:30 PM
sharkey
June 6th, 2013 04:08 PM
Al Sanchez
May 8th, 2012 04:31 PM
70Cutlass_408
July 30th, 2011 02:50 PM
tarps3
Brakes/Hydraulic Systems
June 29th, 2008 04:18 PM
Quick Reply: TH400 leaking from lower coolant line
