Hurst shift rods
Yes sort of, you need the correct levers and rods for type of trans and shifter you have. Pre '69 Muncie levers fasten with bolts, '69 and up had studs with nuts. Other than that, tunnel clearance is the only issue.
Heating and bending rods to fit can be fun, and time consuming!
hvysupreme
February 18th, 2017 12:40 PM
1970-W30
August 20th, 2016 05:09 PM
Alocatelli
December 10th, 2012 07:49 AM
