T-5 swap
Old December 29th, 2009, 12:54 PM
1964f-85's Avatar
T-5 swap
Well getting ready to yank my Muncie close Ratio for a rebuilt Mustang T-5.
I am rebuilding it with the toughest gears, bearing supports and parts I can find to see if it will hold up (I hope).
Has anyone else put a T-5 behind a 455?
If so I would like to hear about the experience.
1964f-85 is offline
Old December 30th, 2009, 06:26 AM
Not for long!
Also, do you need to change the Ford input shaft to GM?
joe_padavano is offline
Old January 10th, 2010, 08:50 AM
1964f-85's Avatar
minor trimming on the input shaft along with a Mustang clutch disc.
Put one behing a built small block and it lived(s).
i used to drag race with a saginaw 4 speed and it lasted a few yeas before exploding it guts all over the driveway.
I am going to give it a try, it will only take an afternoon to swap back in the muncie if I toast it.
I will keep you posted
1964f-85 is offline
Old April 30th, 2010, 11:42 AM
1964f-85's Avatar
Up date, T-5 is in and working and all is well. 75miles an hour at 1900 RPM!
1964f-85 is offline
'69CutlassVert'
August 25th, 2011 07:19 AM
<maxone>
November 28th, 2008 11:57 PM
<jimmy>
November 18th, 2007 02:09 PM
SUGRUE
February 16th, 2007 08:08 PM
ferg87
August 3rd, 2004 08:33 AM
Quick Reply: T-5 swap
