Rebuilt 62 F-85 Roto -5 leaking from vent
Old October 2nd, 2016, 05:15 PM
russell-t's Avatar
Installed professionally rebuilt Roto-5 in a 62 F-85. Adjusted the linkage and filled it to the full line. Had to adjust the linkage 3 more times to get the 1-2 shift right. Drove the car about 5 miles and upon return noticed a large puddle under the car. Fluid was pouring out while idling in park.
Checked fluid level and it was down from full. Parked the car and waited for 3 days,figuring it would settle down after that time. Fluid check showed it just below the add line.Drove car about 3 miles,flared 1-2 shift due to low fluid.Returned home to find fluid again dripping from the vent.
Thought venting fluid would stop after level dropped..not the case.
Can anybody explain what is going on here?
russell-t is offline
Levellord
May 9th, 2016 06:47 AM
Pokefase
23
June 6th, 2015 05:31 AM
Arrowstorm
August 14th, 2014 04:07 PM
bgoble
April 19th, 2010 04:18 PM
Quick Reply: Rebuilt 62 F-85 Roto -5 leaking from vent
