Jerico 4 speed
Jerico 4 speed
Has anyone put a jerico “top loader” behind their olds? I have the chance to get one, it has the 1 3/8’s 10 spline input which looks like it’s also longer then a Muncie/t10 input shaft.
I bought mine with the GM 26 spline input and it came about 1/4" longer to work better with an aftermarket bellhousing with block plate. The 1-3/8 is a Ford spline and normally would be shorter in length than GM inputs.
The 1 3/8 is supposedly the way to go as far as strength and clutch selection. I am concerned about bellhousing bolt pattern and pilot bearing match up. The tranny is too cheap to pass up but don’t want a hassle to get it to work.
