help me identify this please
Old August 16th, 2012, 11:24 AM
lowkey235's Avatar
1966 toronado barn find. it is connected to the throttle linkage and wired to the transmission. My guess is its a transmission kick down. doesnt show up on my wiring diagram shows up in the transmission section of my manual refered to as the stator..but cant find anything else. what is it and what would the symptoms of it failing be...looks like mice have been at the wiring.
lowkey235 is offline
Old August 16th, 2012, 04:46 PM
Just the facts...
BILL DEMMER's Avatar
that's the throttle bellcrank assembly. it also has the kickdown and torque converter pitch switches inside.
bill
BILL DEMMER is offline
Old August 16th, 2012, 05:31 PM
lowkey235's Avatar
Thank you sir.
Old August 17th, 2012, 11:06 AM
Just the facts...
yw.
no need to call me sir
bill
Old August 17th, 2012, 11:30 AM
Eightupman's Avatar
Ah, part of the workings of the "switch pitch" transmission??
John
Eightupman is offline
Old August 17th, 2012, 11:38 AM
Oldsdruid
rocketraider's Avatar
It controls electrical downshift on a TH400 as well as torque converter stator angle on a switch-pitch. Used 65-67. One switch used on 88/98/Cutlass, another on Toronado. There are standard and trailer towing versions of each.
Two obvious symptoms if it's bad or out of adjustment: 1) trans will not downshift and 2) off-the-line performance will be sluggish due to wrong stator angle. Right now I can't remember whether it's stuck in high angle or low angle that causes poor off-the-line acceleration.
rocketraider is offline
Old August 17th, 2012, 12:58 PM
lowkey235's Avatar
found this at 442.com not sure of its accuracy...
To summarize:
Apply 12V ==> hi angle, high performance
No signal ==> low angle, better economy
Old August 17th, 2012, 10:57 PM
Just the facts...
John
that's the facts, jack! (juan)
bill
Old August 17th, 2012, 10:59 PM
Just the facts...
also, switch pitch was to reduce a vehicle's tendency to "creep" requiring a lighter foot on the brake when stopped for a stoplight, etc.
bill
keiperrc
September 17th, 2014 09:14 AM
AK71CutlassS
May 28th, 2014 07:16 AM
JJSCUTLASS
October 23rd, 2012 04:05 PM
Rick E
May 12th, 2012 07:12 PM
oldsrocket88
March 1st, 2012 11:38 AM
Quick Reply: help me identify this please
