Gear Vendors overdrive unit in my 65??
Old October 29th, 2011, 06:03 PM
Bill in NC's Avatar
I've been searching around for install pics of a GV overdrive unit in a 64/65 a-body. I might be mistaken, but I thought years ago I had read an article about the trans tunnel being too tight for the GV unit. Do we have any members here running this set up? Any help would be great guys. Thanks in advance.
Bill in NC is offline
Old November 1st, 2011, 06:02 PM
therobski's Avatar
I thought about that swap too, but I'm building the 64 post with a " built" 200R4.
therobski is offline
Old November 1st, 2011, 08:59 PM
TripDeuces's Avatar
I wanted to do this with my TH400 in my 66 Cutlass. Looking at the photo it doesn't look much larger than the tail shaft end. It's clearly larger but not by much. I've heard that slight massaging is sometimes needed on the tunnel to make it clear in some cases. Nothing a three pound hammer can't fix.
TripDeuces is offline
Old November 2nd, 2011, 06:33 AM
I agree with tripdeuces!
oldcutlass is online now
Old November 2nd, 2011, 07:28 AM
firefrost gold's Avatar
I have one in the mail I have read that it is the sixe of a coffe can. I have read that one can touch the tunnel or make a drop mount cross member to
give you more room and a better drive shaft angle. Was thinking of putting a few washers under the body mount and get some needed space for it too?
firefrost gold is offline
Old November 2nd, 2011, 04:47 PM
Bill in NC's Avatar
I think the GV unit will be the plan come tax return time. It is an expensive solution, but the 400 in the car now is a nicely built unit that should be reliable for many years to come. And if there is a problem down the road I will only be building another 400 and not an expensive 2004r. I can't even seem to find a pic of a GV unit in a 65 Chevelle.
Rallye469
July 7th, 2017 11:07 AM
montvaleplace
April 13th, 2014 05:04 PM
redvettemike
December 20th, 2012 05:07 PM
Stevec
March 13th, 2012 06:11 PM
steve terry
January 13th, 2010 07:14 AM
Quick Reply: Gear Vendors overdrive unit in my 65??
