57 Olds 4 speed auto I dropped it, help
Old July 25th, 2008, 06:15 AM
Junior Member
Nailhead 88's Avatar
I was sliding the 57 Olds 4 speed Jetaway off the tailgate on a piece of plywood, turned away for a second and it slid off the wood and hit the garage floor
It landed on the torus bowl? i think thats what it's called ,it bolts up to the flywheel
it was on it's side, some fluid came out about a hand full
Question should you be able to wiggle that piece in & out? or is that the way it is?
it was raining out, a down pour should of covered it and waited till later -
should of - should of it doesn't pay to rush thing some times
Thanks for any help
Nailhead 88 is offline
Old July 28th, 2008, 02:38 AM
Junior Member
What i was referring to earlier, the correct name is torus cover assembly - the piece the flywheel bolts to
thats what hit the floor first then the cast iron case
any guys had this a part? the torque converter does not have any play just the torus cover
Old July 28th, 2008, 10:33 AM
Junior Member
88 coupe's Avatar
Glad you bumped it. I intended to respond, but I lost it.
Originally Posted by Nailhead 88
........ 57 Olds 4 speed Jetaway ........
All Jetaway Hydramatics had 4 speeds.
........ should you be able to wiggle that piece in & out? ........
Yes.
Like with a torque converter, the slack is there to compensate for any possible dimensional differences, between the block, crank, flywheel, torus cover, and bell housing.
Possible, but very unlikely, that a 3 ft drop would have damaged anything.l
Norm
88 coupe is offline
Old July 28th, 2008, 02:47 PM
Junior Member
Thanks Norm, your the man on Olds info
I just picked up my 50 Olds fenders yesterday i bought in Elverta, Ca
a nice pair, had a friend haul them back
69OLDSCUTCONV
May 18th, 2011 03:51 PM
moberg
Ninety-Eight
22
December 27th, 2009 09:13 AM
Alocatelli
Drivetrain/Differentials
March 12th, 2009 04:43 AM
moberg
March 4th, 2009 12:13 AM
Rangerdog
October 4th, 2008 05:01 PM
Quick Reply: 57 Olds 4 speed auto I dropped it, help
