350 Trans Tail Bearing
While replacing my trans mount I noticed there is too much play in the tail shaft bearing. The bearing that the drive shaft goes in to the rear of the tranny. I don't know if I am correctly naming the part? The manual does not list a part number or a description? Does anyone know the correct part number, name or how to remove it? is it pressed in? Do I have to get to it by removing the tail shaft? I have a 1971 Cutlass 350cidwith a 350 3 speed tranny.
John
John
Why do you think it's bad?
If it's because you could grab the output shaft and wiggle it around after you pulled the slipyoke out, then the output shaft bushing is fine. The bushing rides on the slipyoke, not the output shaft, so when the slipyoke is removed, the output shaft can wiggle around.
To check it, re-insert the slipyoke and then check for play .
Hi Eric,
Thanks for helping me out. About 2 weeks ago I installed a manual hurst floor shifter and the drive shaft was hitting the installation bolts on the shifter when I drove the car and it was under load? So I changed the trans mount and changed the bolts to carriage bolts and installed them from the bottom up. I noticed that the drive shaft has been hitting the underside of the floor for sometime prior to the floor shifter installation. When the drive shaft is in place you can grab it and move it around way to much. So that is why I want to replace the tail shaft bushing. I found a complete rebuilt tail for a reasonable price. What do you think?
If the front U-joint is all over the place, then I agree, the bushing is bad.
If you can get a hold of a good tail piece, that should do it. You can make sure by inserting the slipyoke into the new tail piece before you even install it, to see if it fits with only a few thousandths play.
It should be a simple matter to unbolt the tailpiece (be ready to catch all the oil!), and slide it off, but I will admit that I've never actually done this before myself.
Good luck!
Good luck!
Thanks Eric!
I am going to order the entire tail piece. I did a little research online and someone went through a lot of problems by just changing the busing several times because they damaged it and the part did not fit correctly and had to be machined down finally to make it fit correctly. I figure for a rebuilt one at $68 is a bargain! My only concern is a correct fit for the drive shaft. There are 2 different seals small and large shaft's on year one's website. I have a th350 so I am assuming it’s the smaller one? Any thoughts on that?
Thanks again,
John
Thanks again,
John
As fas as I know (I'm not crawling under the car in the snow, and my spare TH400 is a few hundred miles away),
YES for the TH400 (at least in some cases), and
NO for the TH350 (but it's easy to remove in order to pull the tail if I'm wrong).
Thanks Eric, I talked with a supplier on eBay. He has every size. He told me to measure length and dia of speedo housing. I should be able to get the correct one. I'll keep you and everyone else posted.
Flye
Drivetrain/Differentials
July 30th, 2009 10:24 AM
