Transaxel positraction
Old November 19th, 2008, 04:50 AM
oldsvair's Avatar
Is they any way to get posi traction from a stock 455 transaxel with a TH425?
oldsvair is offline
Old November 19th, 2008, 05:07 AM
Past Administrator
Oldsguy's Avatar
Monzas would be the first person I would ask.
Oldsguy is offline
Old July 10th, 2020, 10:29 AM
Eric Rhodes's Avatar
Answer
Did you ever get an answer?
I am wanting to put the drivetrain in the back of my Hearse. Can positraction be accomplished on the TH425
Eric Rhodes is offline
Old July 10th, 2020, 10:51 AM
How much do you want to spend? The GMC Motorhome community has these available. They are not cheap.
https://www.gmcrvparts.com/product-p/gm17-17.001.27.htm
joe_padavano is offline
Old July 12th, 2020, 08:08 AM
Killian_Mörder's Avatar
There's no such thing as expensive and cheap. Only rich and poor
There may be a good reason as to why manufacturers were reluctant in offering limited-slip differentials in front-drive vehicles. In a worst case scenario where an inexperienced driver was to apply too much acceleration around a wet or icey curved road, both front wheels could break loose from roadway traction, causing the vehicle to lose control which would be worse than when the rear axle would lose grip, because the front wheels could still compensate for rear axle traction loss through steering compensation. This was the main reason as to why electric-powered bicycles with front-mounted motors aren't generally prefered over ones with rear wheel-propelled versions.
A motorhome has somewhat different dynamics over a passenger car, in that the front axle is also supporting driver and co-pilot weight, as well as more of the body shell structure. A motorhome is also mostly driven under pleasant weather conditions and at slower speeds than a gentleman's front-drive luxury muscle car.
If the idea is to dragrace a Toronado, there's no better solution than to install Joe's pictured unit
Killian_Mörder is offline
Old August 4th, 2020, 05:59 PM
EightballZ's Avatar
throughout the years that topic came up several times BUT somehow i've never met anyone who pulled the trigger and installed this unit in a toronado. once i'm back home (2022) i'm gonna order one - unfortunately theres no used parts in the market so gonna pay full - and shipping to germany....aaand core deposit -.-
though i've heard other companies can build one as well - but they don't offer other gear ratios
EightballZ is offline
Old August 4th, 2020, 11:04 PM
Perhaps, this subject should get a "sticky", since it frequently arises. All of these threads discussing this device should get consolodated, IMHO
Originally Posted by EightballZ
...i'm gonna order one -...
...- and shipping to germany....aaand core deposit -.-...
As long as the inspection authorities (T.Ü.V., DEKRA) don't notice this modification, you should have no trouble getting your certification
Old October 17th, 2020, 09:55 AM
Golden Pig's Avatar
So I just picked up a cherry 68 Toronado and will pull the trigger on this. Will document for everyone. Going with the 4:10 option. How much can it hurt 7 MPG? lol.
Golden Pig is offline
Old October 17th, 2020, 10:03 AM
It depends. Only hard working engines guzzle fuel. A 4:10 around town should get more MPGs than lower numbers:10
Old October 18th, 2020, 06:08 PM
EightballZ's Avatar
oh now thats some great news!!
Old October 29th, 2020, 08:10 AM
Golden Pig's Avatar
March 20th, 2018 06:07 PM
September 22nd, 2015 02:10 PM
sammy
November 3rd, 2013 07:11 PM
TooFoolishOlds
April 10th, 2011 09:21 AM
charlierogers
January 6th, 2011 05:56 PM
Quick Reply: Transaxel positraction
