69 Toro Output Shaft assembly needed
Is anyone parting out a 69 Toro? I need the output shaft (jack shaft) assembly. Let me know. The front pinion bearing in my 67 differential blew apart and ruined the diff. I have a diff from a 69 that is fine, unfortunately the output shafts are different.
If you haven't looked through the parts for sale section you might give that a try. I believe there's been a couple 1968-69 Toro's being parted out in the last year. Too bad I'm on the other side of the country, I've got several 1966-67 transmissions/transaxles from Toronado's. If you don't find something closer, I still have this:
https://classicoldsmobile.com/forums...ferential.html
John
John
I didn't know they were different. Ratio different?
MLK-442
March 21st, 2012 11:08 AM
