Best fitting headers 1972 455
Just curious what headers you guys have had luck with... I currently have older set of hookers that hang quite low and wondering what everyone else has had luck with..
im currently looking at a set of Dougs..
On my '72 project I bought some good used headers and had them coated. When I installed them one tube rubbed on the brake junction block bolted to the frame under the master cylinder. I have read of this problem before but maybe its my motor mounts? My car is a U code, 455 but when I bought it there was a 350 2bbl under the hood. Now it has a '72 455 but the fan is too low in the shroud and rubs at the bottom inside. I guess I should look into whether I have the right mounts?
