Replacing leaf springs on 60 Olds
Old September 4th, 2010, 06:18 PM
misercola's Avatar
Hi,
Back end of my 60 convertible is lower than I would like and after examining the rear suspension on a lift today have decided it's time to replace the leaf springs. Can anyone recommend a supplier? Am not seeing much on Hemmings and they don't seem to carry the ones that go on my car.
Thanks,
Mark
misercola is offline
Old September 4th, 2010, 07:32 PM
jaunty75's Avatar
Fusick has them on page 57 of their "early Olds" catalog (#530).
http://www.fusick.com/catfile/Catalo...Layout%201.pdf
They're not cheap at $425 a pair. Just out of curiosity, have you tried a local spring shop? I wouldn't think that leaf springs have changed all that much through the years, and a local shop might be able to do something for you. Maybe I'm wrong, but if it were me, I'd probably make some calls before spending nearly half a grand.
You might try this place, too.
http://www.eatonsprings.com/
jaunty75 is offline
Old September 5th, 2010, 09:38 AM
citcapp's Avatar
There used to be suspension shops around that could re-arch springs the re-temper them so they would maintain the new arch. Had this done to my 56 chev and a jeep I owned a number of years ago and it worked great. Might check for one in your area.
citcapp is offline
Old September 5th, 2010, 12:16 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I don't know if there are any shops in your area or not since I don't know where you are but I would for sure look at having them re-arched. We did that on my friend's 54 and it worked great. It is a lot cheaper, you have no freight (springs are heavy) and you don't get Chineseum steel.
redoldsman is online now
Old September 5th, 2010, 05:10 PM
There are spring shops in every metropolitan area. Just look under truck springs in the yellow pages. Most will also make U-bolts for leaf springs while you wait.
joe_padavano is offline
rmoths
October 28th, 2013 10:29 AM
dom1n1c
February 22nd, 2012 07:31 PM
TheBirds
Suspension & Handling
May 5th, 2011 09:21 PM
misercola
September 14th, 2010 08:22 AM
Fletch
January 20th, 2010 02:10 PM
Quick Reply: Replacing leaf springs on 60 Olds
