Rear Shock Installation Question
Old April 30th, 2011, 03:51 PM
O's_Car's Avatar
I just installed new rear shock absorbers on my '70 Cultass S. They're KYB Gas-a-Just shocks and I installed them with the supplied hardware. My question relates to the lower attachment to the rear axle. The shock appears to be quite twisted in relation to the axle stud - see the pictures below. The shock looks like it might pull off of the rubber bushing. Now at the moment the body is off the frame, so there's no weight pushing down on the suspension. I'm a little concerned - do I have a problem here or should I wait and re-evaluate when there's body weight on the suspension? Any insight would be appreciated.
O's_Car is offline
Old April 30th, 2011, 04:58 PM
ziff396's Avatar
Looks like the shocks when we used to jack up the rears in highshool back in the day. I would say that the rear is to high without weight on it. Otherwise, adjustable upper control arms will solve the problem if your driveshaft is in the same off angle.
ziff396 is offline
Old April 30th, 2011, 05:06 PM
DJS70cutlass's Avatar
I think your good, the weight of the body will straighten that right out.
DJS70cutlass is offline
Old May 1st, 2011, 06:34 PM
O's_Car's Avatar
Thanks guys! I'll check it again when the body is on.
O's_Car is offline
Old May 1st, 2011, 08:16 PM
Big Blue 72's Avatar
Mine were the same way when I put my KYBs on about a year ago. I haven't put 5 miles in them since so let us know if they straighten out ).
Big Blue 72 is offline
Old May 2nd, 2012, 08:58 PM
JC
JCMC64's Avatar
I dont know if the body being off has anything to do with it. I have same shocks on 71' Cutlass S, with body on, and it does the same thing. Though I do have the interior out, so it is lighter. But it looks exactly like OP pics.
JCMC64 is offline
foo
Suspension & Handling
October 28th, 2012 07:01 AM
yeahbuddy
December 19th, 2011 08:40 PM
oldzzy
September 11th, 2010 07:13 AM
msco123
August 9th, 2009 11:07 AM
B-Mann
May 1st, 2009 12:02 PM
Quick Reply: Rear Shock Installation Question
