Power Steering Return Line Leaking
Old September 15th, 2023, 02:59 PM
NTXOlds's Avatar
About a year ago, I had a shop replace my power steering box with a quick ratio unit from OPGI. It started to leak at the return line not too long ago, and it seems to be getting worse. The fitting seems plenty tight, although it also looks a bit boogered up and rounded.
I can feel that the fitting is dry below the rubber line, and it definitely looks and feels wet where the line and the nut intersect. It then is leaking down to the threads. (SEE PHOTO)
Replacement fittings from OPGI and Fusick do not show any kind of gasket or fitting other than the metal line and nut themselves, but O'Reilly's has replacement fittings with various o-rings and conical gasket-like pieces. Is there anything beyond the line itself that is required? I did check the service manual and could not find any reference to anything other than the fitting itself.
NTXOlds is offline
Old September 15th, 2023, 07:02 PM
It depends on whether your replacement box is the early style with inverted flare fittings or the late style with o-ring fittings. Inverted flare fittings are metal-to-metal seals.
joe_padavano is offline
Old September 15th, 2023, 07:21 PM
NTXOlds's Avatar
Thanks, Joe. I tried calling OPGI earlier today to find out, but they never called me back. It should have been the inverted flare at least based upon the image, but I guess I’ll have to just remove the line and see for myself.
NTXOlds is offline
Donaldbabineau
May 17th, 2022 06:50 AM
rocketscientis
May 24th, 2020 06:05 PM
RandyS
Suspension & Handling
March 10th, 2020 11:37 AM
Chuxter
October 31st, 2016 04:57 PM
Flye
July 31st, 2009 04:03 PM
Quick Reply: Power Steering Return Line Leaking
