Help With Pterodactyl in my PS
The chirp is most prevalent when the car is cold and I try to turn the wheels when the car is stationary or at slow speeds. it doesn't sound like a constant little sparrow chip that might indicate misaligned pulleys. there is resistance to turning the wheel, then the belt slips and makes the noise. resistance is more pronounced turning right, but is there both ways. some times the resistance suddenly goes away. once car is warm and i'm moving, i don't feel it until i slow down <15 mph, and make sharp turns (like in my parking garage.) I rebuilt the pump last summer and replaced both lines. Hot level is correct, fluid has maybe 7000 miles, no bubbles in the pump reservoir that I can see, no leaks out of the pump, lines or box that i can see, belt looks OK - a little shiny on the sides. could be that i put the pump together the wrong way, but i rebuilt it to fix this problem - so it existed before i got my hands on it. i'm petty sure the root cause is the resistance, thoughts? i'm sure this is a common problem with old PS equipment, what are the usual causes?
If you push down in the middle with one finger, pretty hard, it should deflect about ½".
You shouldn't have to push down very hard, but the difference between very hard and pretty hard can be hard to convey, and if you think it's at pretty hard and it squeals, then tighten it to very hard.
http://www.ebay.com/itm/Automotive-B...328b19&vxp=mtr
Normally over $100
I do a bit of work with belt driven fans, so we need accurate tension information.
Normally over $100
ToronadoGuyDenver
Brakes/Hydraulic Systems
March 18th, 2007 02:52 AM
