performer rpm intake on # 7 heads
Old Jan 4, 2009 | 04:34 PM
GothamCity's Avatar
Need help on the installation of the intake manifold. I have removed the old intake and installing the new one. My question is I have 4 holes in the intake. I was able to plug 3 of them with the plugs supplied. The forth hole which is on the left rear side near the distributor is considerly larger. My question is does this hole need to be plugged or is it to be left unplugged. A quick reply would be helpful. the engine is 350 olds
Last edited by GothamCity; Jan 4, 2009 at 04:35 PM. Reason: needed to add additonal info
Old Jan 4, 2009 | 04:48 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I plug everything for the install. As I need to add parts, I take out the plugs.
Old Jan 4, 2009 | 04:51 PM
Redog's Avatar
Sounds like the heater control valve is missing
Old Jan 4, 2009 | 04:54 PM
GothamCity's Avatar
[QUOTE=Redog;56932]Sounds like the heater control valve is missing [/QUO
on the old inake there is still a hole that is plugged, it looks different than the others..it's larger in diameter
Old Jan 4, 2009 | 04:55 PM
GothamCity's Avatar
yhanks for quick reply
Old Jan 4, 2009 | 05:12 PM
GothamCity's Avatar
thanks guys..my car did not have a/c nor heater hooked up..so thats why this didnt look familar...the old intake has this capped off, I will try to remove this one off and use it until get the heater stuff worked out
agtw31
Feb 17, 2024 09:48 AM
70Cutlass_408
Jun 16, 2011 11:48 AM
Aceshigh
Sep 25, 2010 05:32 PM
Gearhead442
Mar 16, 2010 12:59 PM
