Carb issue maybe? 72 350
Old December 14th, 2014, 04:42 PM
my72olds's Avatar
The orig carb just got back from sparky , put it on and seems to run good till you put it in r or d. I can't even keep it running in r. I am able to keep it running in d but its not easy. I don't understand , the carb that's been on the car for the last few months is from a gto I think it ran and drove fine with it only problem was secondary wouldn't open. To keep things orig I sent orig carb off and now it's back and on something's not right... Any ideas.
my72olds is offline
Old December 14th, 2014, 05:06 PM
Old School Olds
tru-blue 442's Avatar
Check for vacuum leaks. If that doesn't do it, call your re-builder and explain the problem.
tru-blue 442 is online now
Old December 15th, 2014, 03:22 AM
FMB42's Avatar
Yep, that would be my first thought. Have you checked the manifold vacuum at idle? Also double check anything changes or adjustments that you might have done just prior to and during the carb rebuilding/installation. Also make sure that the vacuum lines are connected properly. Then make sure that the timing, dwell, state of tune, carb mixture screw setting(s), choke fast idle, and warm engine idle speeds are all OK and/or set as per the service manual.
FMB42 is offline
Old December 16th, 2014, 07:58 PM
my72olds's Avatar
I pulled a carb off that ran fine on it for months but secondary's won't open, I took it off out the fresh one from sparky which is orig carb never had to modify or add or change anything they both plug and play here . As long as there is no load on it it revs fine but as soon as you put it in gear it starts trying to die on me. Tomarrow ill mess with it a little more
my72olds is offline
Old December 16th, 2014, 08:50 PM
Octania's Avatar
Advance the timing
Use the vacuum advance direct to manifold if need be.
Octania is offline
Old December 19th, 2014, 05:40 PM
captjim's Avatar
Originally Posted by Octania
Advance the timing
If it ran fine before, I think it must be carb related, I would not start changing other things just yet. Sparky has a solid rep, have you tried calling him for a bit of assistance?
captjim is offline
Old December 19th, 2014, 10:57 PM
my72olds's Avatar
I did I spoke with him yesterday and he told me to make a couple adjustments I hope maybe this weekend ill get to it. Been busy fixing up the inside I'm my new shop : wire ; insulation but first chance I get ill get my daughter out to help me
my72olds is offline
1yesfan
August 4th, 2015 06:40 PM
Dead Reckon
July 14th, 2014 02:35 PM
Dustin1706
April 24th, 2014 04:23 PM
gbody 442
July 24th, 2013 07:41 PM
Aceshigh
April 5th, 2010 04:13 AM
Quick Reply: Carb issue maybe? 72 350
