swapping motors
Old Mar 5, 2008 | 10:31 PM
oldstay's Avatar
swapping motors
will a 1964 190 hp 330 fit in my 1963 f-85 instead of my 215?
Old Mar 6, 2008 | 06:16 AM
Depends. How are you with welding and fabricating?
The 61-63 cars are completely different from the 64-72 cars. For one thing, they're unibody as opposed to body-on-frame. The 215 uses a unique motor mounting and bellhousing design.
It's certainly POSSIBLE to fit a 330 (or any SBO - or BBO for that matter). Pontiac offered the 326 in the 1963 Tempest, so the SBO will likely fit. It will NOT be a bolt-in, however. You'll need to fabricate pretty much everything.
Old Mar 6, 2008 | 02:48 PM
88 coupe's Avatar
Junior Member
........ Pontiac offered the 326 in the 1963 Tempest ........
Standard was the "half 389" inline 4, which shared mounts with the optional 326. Made the 389/421 a bolt in, so the GTO could have easily happened a year earlier.
F-85/Cutlass/Jetfire and Special/Skylark front clips can be easily unbolted, and interchanged. If they are the same as Tempest/Lemans, it would make the conversion easier. Increased torque of the 330 might call for a sturdier drivetrain. Wimpy brakes would also need to be addressed.
Norm
RichardWilliams
Apr 7, 2009 08:18 AM
jmac69cutty's
Oct 31, 2008 12:28 PM
59-59-59
Apr 16, 2008 09:13 PM
dhoopty
Drivetrain/Differentials
Apr 16, 2008 09:45 AM
