freeze plugs?
Old January 8th, 2008, 11:29 AM
wagonman's Avatar
freeze plugs?
Hello .I pulled an engine from storage and I noticed that one of the freeze plugs was rusted out.Motor turns by hand and is out of the car.What is the procedure to repair?Thanks.
wagonman is offline
Old January 8th, 2008, 12:00 PM
dynamic88's Avatar
just pop the old plugs out and go to the auto parts store and get new ones to put back in. its kind of a pain in the *** if they are all rusty and stuck in there. you can get them out with a screwdriver and hammer. just work it back and forth from side to side . new ones just pound back in with a rubber mallet.
dynamic88 is offline
Old January 8th, 2008, 12:09 PM
wagonman's Avatar
Thanks for the reply .Iwas wondering about if I had to flush it incase there was rust debris in the block?
wagonman is offline
Old January 8th, 2008, 01:46 PM
I wouldn't worry about it, though I would replace ALLthe freeze plugs with brass while the engine is out.
joe_padavano is offline
Old January 8th, 2008, 01:49 PM
wagonman's Avatar
Thanks.
wagonman is offline
Old January 8th, 2008, 02:09 PM
The_Jeremiah's Avatar
yes definently replace them all, its like 8 bucks i think for the bag at the store, use a hammer and punch and hammer on one side to see if you can rotate the plug in place and pull it out with some pliers. If you accidently knock one into your engine, dont worry, just use a big screwdriver and your fingers to get it back to the hole, and grip it pretty tightly with some pliers and pull it out. you might want to use a little black rtv on the new plugs just to be safe. good luck
The_Jeremiah is offline
Old March 6th, 2008, 04:37 PM
1973cutlass442's Avatar
freeze plug problem please help
i have a freeze plug question i have a 73 442 with the left side freeze plug missing i have bought the new one and was wondering how i would put it in with the motor still in the car theres not much room for swinging a mallot and ive tried to pull the exhaust header off but thats not goin to well i was hoping to not hav to do that if there is anyone that can help me with this problem that would be really helpful.
1973cutlass442 is offline
Old March 6th, 2008, 05:00 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Hmm.....
Jack it up and take a wheel off maybe? At least you'll have a straight look at what you are messing with.
Sounds like a royal pain.
J-(Chicago) is offline
Old March 7th, 2008, 06:49 AM
This is often a problem. There is a rubber expanding freeze plug available that you can press in by hand and then tighten with a wrench. Not the preferred solution but an expedient way around the clearance problem.
sparx50
August 19th, 2014 11:38 PM
Caveman-455
May 7th, 2012 05:49 PM
Rich
September 4th, 2010 05:14 PM
Joeypete
October 16th, 2009 10:43 AM
gthmcty1
July 12th, 2009 08:39 AM
Quick Reply: freeze plugs?
