350 rocket 1972 cuttlas problem
Old September 22nd, 2010, 05:10 PM
mryoung4815's Avatar
Question 350 rocket 1972 cuttlas problem
I have a 72 olds cuttlass s 350 rocket and I lost the power steering belt and the alt belt so I bought new belts so when I took the alt bracket and power steering pump and neg ground bolts I don't rember how they go back I don't have ac at all so is there a diagram I can go by to put it back together properly.?
mryoung4815 is offline
Old September 22nd, 2010, 06:51 PM
69oldsguy's Avatar
You really didn't need to take any brackets apart. You only have to loosen the pivot bolts and the slide adjustment bolts.
Anyway, your alternator should be on the passenger side and the P.S. on the drivers side. Is there any way you can post pics of the brackets that you have disassembled? I really have no way of knowing what all you have taken apart without pics.
69oldsguy is offline
Old September 23rd, 2010, 03:01 PM
i just uploaded some picks for you
Old September 23rd, 2010, 04:11 PM
citcapp's Avatar
No pictures did you go to manage attachments at the bottom of the page after hitting reply at the top of the page then follow the directions
citcapp is offline
Old September 23rd, 2010, 04:30 PM
pics
this should do it
Old September 23rd, 2010, 08:56 PM
70 cutlass s's Avatar
The pic in the middle that bracket bolts to the the lower alt. bracket and to the back of the alt. When you look at the back of the alt. you will see a bolt hole for it.
FYI your bracket and pulley setup is for a car with A/C. Some one most have remove the compressor at some point.
70 cutlass s is offline
Old September 24th, 2010, 01:51 PM
69oldsguy's Avatar
X2. Either it is an A/C car or someone put an A/C motor complete with alternator in.
70 cutlass has you on the right track. You'll get it back together.
oldman72
August 25th, 2011 09:41 AM
dharlett
September 23rd, 2009 03:30 PM
BigBertha442
April 10th, 2008 10:10 AM
1972madison
July 10th, 2007 02:32 PM
Quick Reply: 350 rocket 1972 cuttlas problem
