vaccum gage and timing
Old Aug 26, 2009 | 04:07 AM
65cutty's Avatar
am wanting to set my timing with a vaccum gage. I was told its a better way. hows this done?
Old Aug 26, 2009 | 06:17 AM
There is. Use a timing light.
You hook up the timing light, set your idle to the specified rpm and use the timing light to set your "timing mark" on the harmonic balancer to the specified advance.
Use a vacuum gauge to set your idle mixture screws.
Old Aug 26, 2009 | 07:05 AM
No, you're not...
Old Aug 26, 2009 | 11:27 AM
380 Racer's Avatar
No, you're not...
Old Aug 26, 2009 | 12:49 PM
Supposedly there are old timers that can tune a car by ear or with a small glass of water on the air cleaner. I've never seen it though. Plus, why try to be that cool if you have tools to do it with?
Old Aug 26, 2009 | 01:14 PM
wmachine's Avatar
Trying to remember member
It's really not that hard to do by ear, within 3-4 degrees. But that isn't good enough.
Old Aug 26, 2009 | 01:43 PM
I agree.
Old Aug 26, 2009 | 01:46 PM
Bluevista's Avatar
Registered
You just cut a hole in the firewall and reach up and time it on the fly, believe it or not I've seen it.
Crude and early version of dial-advance.
Old Aug 27, 2009 | 02:45 AM
Yellowstatue's Avatar
Wink Reach for it
Buick guys can't do that because their arms are too short!!!
Old Aug 27, 2009 | 04:03 AM
65cutty's Avatar
not trying to be cool, I can get a precise timed engine if vaccum is at the highest then backed off just a little, and with a cam there timing is just a starting point, air fuel mixes? tried that last nite and it works also went for the highest setting then tighten 1/4 turn, car runs the best it ever has since rebuild, doesnt load up hot and no stumbling. yes the rpm must be set and dist vac blocked.
Old Aug 27, 2009 | 05:59 AM
Well if it works for you then that is good. Never heard of setting timing with a vacuum gauge though...
JpMotorsports
Oct 13, 2015 01:07 PM
jonesolds442
Dec 3, 2013 05:00 PM
StickW31
Jan 8, 2013 08:08 AM
442scotty
May 13, 2009 05:42 PM
a6m5zerosen
Jan 14, 2008 05:11 PM
