1971 oldsmobile cutlass with a 307 engine trying to find the year the engine was made
I have a 1971 oldsmobile cutlass with a 307 engine iam trying to find the year that the engine was made.?
Iam trying to find what year my 307 engine was made in; it has all these Numbers on the the engine and the block . Its a 5 liter V8; its has this number 7A on the head engine its has these number 6509GM5.OL, GMY411961 and D1-2061 on the engine and block. Exhaust Manofold is 142 the, the Oil Filter PT6L Ac Delco
hmm, I have some ID books at home. Maybe this link can help you out.
http://www.442.com/oldsfaq/ofeng.htm
then go here
http://www.google.com/url?sa=U&start...dJr7VcK3751IFg
Talks about Julian date codes on the blocks.
Why is it you need to find this out? Its obvious that its not the original motor for this car.
then go here
Tune up Concerns
Thanks For the Reply well iam trying to find the right air, gas and fire mixture and the RPM is to high its at 880 and the Timing is set at 0 which is not right. Plus i need to know the exact year for parts and tune up because the spark plug my be wrong.
The year of the motor won't do you any good with tune up specs. In stock form, the 307 used the Computer Command Control (CCC) system that electronically controlled spark advance, mixture ratio, and a host of emissions equipment like the EGR valve and the A.I.R. system. I assume your car does not have this hardware, so someone has installed the non-computerized carb and distributor from a different year and engine size. You'll need to use trial and error to find the right adjustments, I'm afraid.
Lemar
July 9th, 2014 06:02 PM
ELECMAN
January 27th, 2011 09:20 AM
