307 y vin timing adjustment
Old February 27th, 2017, 05:07 PM
deltsanddueces's Avatar
can someone run me through the process of adjusting the timing on one of these 80's computer controlled distributors, I know I have to ground the computer but I don't know what to unplug
deltsanddueces is offline
Old February 27th, 2017, 05:41 PM
BillK's Avatar
Exactly what year and what car ?
BillK is offline
Old February 27th, 2017, 05:46 PM
85 delta 88
Old February 28th, 2017, 10:33 AM
SEARCH is your friend:
https://classicoldsmobile.com/forums...djustment.html
Bottom line is that you don't disconnect anything. You simply jumper the A and B terminals in the ALDL connector to ground the diagnostic lead.
joe_padavano is offline
Old March 1st, 2017, 08:04 AM
might be a stupid question but where is the ALDL connector located
Old March 1st, 2017, 08:36 AM
Under the dash, below the steering column.
Old March 1st, 2017, 08:39 AM
If you plan to do any work on this car, get a set of these. There are many on ebay right now, with prices under $20.
Old March 1st, 2017, 03:17 PM
BlackGold's Avatar
On the G-bodies it's closer to the center of the dash. Is it really under the steering column for the Delta 88?
BlackGold is offline
Old March 1st, 2017, 03:28 PM
Yep.
Old April 14th, 2017, 12:09 PM
Yep.
Is the timing supposed to be at 20 degrees btdc with the test lead grounded or is it supposed to be at 20 degrees without the test lead ground,
Old April 15th, 2017, 09:48 AM
Did you read the link back in Post #4 or the CSM?
In any case, here's a little common sense: The computer is constantly varying the timing based on multiple sensor conditions. If you try to set the timing with the computer active, it will continue to vary the timing while you are setting it, meaning you will NEVER get an accurate initial timing set. Jumpering the ALDL connector as described above locks out the computer so you can set the timing properly.
Old April 15th, 2017, 12:26 PM
Ah ok I gotcha, thanks Joe
70-442-W30
August 10th, 2016 04:38 PM
kanek4
May 28th, 2014 05:41 PM
bdub217
July 18th, 2012 10:35 AM
Rob delta
April 24th, 2012 07:38 PM
442scotty
May 13th, 2009 05:42 PM
Quick Reply: 307 y vin timing adjustment
