Q-Jet "Not Recommended" on Performer RPM Intake
Old January 11th, 2017, 06:03 AM
glamaina's Avatar
So Im looking at the RPM intake for my rebuild. I also wanted to keep my Qjet and have it rebuilt. However, the documentation for the RPM states that Edelbrock does not recommend EGR-style Quadrajets on the RPM intake. Anyone have any experience with this? My carb is from 72 so it is the EGR style. Whats noticeable is that it says its not recommended and not that's it not compatible.
I would think that you could just bypass/disable the egr on the carb but I do not know too much about these carbs.
glamaina is offline
Old January 11th, 2017, 06:12 AM
Maintained
scottv442's Avatar
i thought the EGR didn't arrive until 1973 model year?
your 1972 should be non-EGR.
scottv442 is offline
You can't install an EGR valve on the Performer RPM intake. A Q-jet will run just fine. The Performer RPM will accommodate a spread bore or square bore carburetor. Since you would have to delete the EGR valve if you swap to this intake, you would probably want to retune your ignition curve and carburetor jets / rods; however, it wouldn't be necessary.
Olds64 is online now
Old January 11th, 2017, 06:29 AM
glamaina's Avatar
Ill have to look when I get home. I was reading last night that it was introduced in 72. If non-EGR then problem solved.
glamaina is offline
Old January 11th, 2017, 06:33 AM
glamaina's Avatar
Thanks, yes I know you cant install an EGR valve on the RPM. I was more curious why they say its not "recommended" to use an EGR Qjet if one could just delete the EGR valve.
glamaina is offline
Old January 11th, 2017, 07:17 AM
oddball's Avatar
Performer RPM doesn't have EGR provisions.
QJets that came on EGR cars are calibrated with an exceptionally lean part throttle to account for the EGR.
Ergo, putting an unmodified QJet from an EGR car onto a Performer RPM leads to bad times.
As with anything, the carb needs to be tuned to the new build. You can use later carbs, they may just need a bit more work than earlier carbs to run well.
oddball is offline
Old January 11th, 2017, 07:23 AM
What, exactly, is an "EGR-style" Qjet?
The only things I can think of that might be different for a Qjet on a car with EGR is 1) the added timed vacuum port to operate the EGR valve and 2) the fact that the primary metering rods are likely to be lean at part throttle.
Neither of these is much of an issue. You can cap the port if you don't have EGR and you can change the metering rods (as you SHOULD anyway to match the flow characteristics of the new intake). Sounds like more uninformed BS to me.
joe_padavano is offline
Old January 11th, 2017, 07:24 AM
glamaina's Avatar
Thanks that what I assumed. Edelbrock is alluding to stock EGR Qjets but they can be retuned to work with non-EGR intakes.
glamaina is offline
Old January 11th, 2017, 07:34 AM
glamaina's Avatar
This is exactly what threw me off. Here is the pic notice the asterisk.
glamaina is offline
Old January 11th, 2017, 08:06 AM
GEARMAN69's Avatar
It is just a disclaimer from Edelbrock so you do not remove or disable 73 and up factory emissions and the lack of the exhaust heat riser plate for the heated tubes to operate the choke. Any Quadrajet would need proper performance tuning to be optimal. Electric chokes are an easy retrofit too.
GEARMAN69 is offline
Old January 11th, 2017, 09:56 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
They are just trying to convince people to buy their terrible Performer 750 cfm carb. Isn't that the worst one of the bunch? I have an EGR QJet on my Performer, tuned like Joe described.
olds 307 and 403 is offline
Old January 11th, 2017, 10:00 AM
GEARMAN69's Avatar
Those Edelbrock AFB style ones are horrible and geeze those horrid adapters over stock Q jet intakes
Old January 11th, 2017, 10:18 AM
derone's Avatar
While we're on the subject of Eldebrock RPM intakes, what fuel line are you guys running from the pump to the carb? Stock 350-4bbl, 455-4bbl, one piece, or a 2-piece line w/filter midway? Pretty sure the intake is a bit taller then the OEM one and trying to put together another order for my build.
thanks,
Doug
derone is offline
Old January 11th, 2017, 10:29 AM
GEARMAN69's Avatar
Originally Posted by derone
While we're on the subject of Eldebrock RPM intakes, what fuel line are you guys running from the pump to the carb? Stock 350-4bbl, 455-4bbl, once piece, or a 2-piece line w/filter midway? Pretty sure the intake is a bit taller then the OEM one and trying to put together another order for my build.
thanks,
Doug
If you want a one piece line with flared ends you will have to make your own. I make my own with 3/8 aluminum line works well. I prefer the filter elsewhere for cleaner look. Fram paper in Qjet inlet minus the check valve crap or inline filter before pump
Old January 11th, 2017, 10:42 AM
derone's Avatar
Suppose I could do that. I'm really wondering if the 455-4bbl line would work on the 350ci, due to the slightly larger dimensions of the 455ci, when using the 350ci RPM intake, and hoping that the line might be slightly longer to compensate. Using a q-jet of course.
derone is offline
Old January 11th, 2017, 10:54 AM
Interesting thought. With stock intakes, the BBO carb sits 1" higher than it does on an SBO, thus that's the difference in fuel line length. I don't know if the RPM carb flange is that much taller than stock on a 350 or not, but you MIGHT be close enough to finesse the line into place.
Old January 11th, 2017, 10:56 AM
GEARMAN69's Avatar
That's a good point joe
Old January 11th, 2017, 11:44 AM
88 Cutty Classic's Avatar
thanks,
Doug
i used this line for the carb
https://www.summitracing.com/parts/edl-8131
for the carb line to the pump i used is summit part number EDL-81233 , edelbrock braided fuel line kit for small block chevy. https://www.summitracing.com/parts/edl-81233
i had to shorten the line and use the following fitting
90 deg bend -6AN male to 5/8-18 inverted flare male
Part number EAR-AT949096ERL
https://www.summitracing.com/parts/ear-at949096erl
88 Cutty Classic is offline
Old January 11th, 2017, 12:17 PM
shiftbyear's Avatar
you carb can easily be converted to electric choke. consider enlarging the idle tubes and idle down channel restriction if running a large camshaft, maybe increase the idle bypass air also. good luck
shiftbyear is offline
agtw31
February 17th, 2024 09:48 AM
70Cutlass_408
June 16th, 2011 11:48 AM
Aceshigh
September 25th, 2010 05:32 PM
GothamCity
January 4th, 2009 05:12 PM
Quick Reply: Q-Jet "Not Recommended" on Performer RPM Intake
