Thermal Ported Vacuum Switch
Old October 29th, 2014, 01:38 PM
jerseyjoe's Avatar
Can someone confirm on a 68 olds 350 a switch that is working properly should supply ported vacuum only to the vacuum advance unless in an overheating situation it would divert to manifold vacuum to increase timing. I have vacuum to the advance both cold and hot at idle. I believe this is incorrect and the valve is stuck open.
joe
jerseyjoe is offline
Old October 29th, 2014, 02:11 PM
hullinger's Avatar
I believe your understanding is correct along with your diagnosis. For me, having the switch stuck open doesn't seem like a problem. On my '73, the switch was stuck closed so I just routed those vacuum hoses to other ports. Regardless, be sure to check your initial and total timing to make sure your getting as much as possible.
Chris
hullinger is offline
Old October 29th, 2014, 03:22 PM
Yes, this, of course, brings us back around to the Ported / Manifold vacuum advance controversy.
My recommendation is to see which way your car seems to run best, and just leave it that way.
The only difference that the TVS makes is to apply full manifold vacuum at idle - the ported vacuum is equal to the manifold vacuum as soon as the throttle plates are cracked, so anywhere above idle, the TVS has no effect.
MDchanic is offline
Old October 29th, 2014, 03:32 PM
drop top olds's Avatar
Any difference in the TVS operation with three hose fittings on the stem verses two?
drop top olds is offline
Old October 29th, 2014, 03:43 PM
I thought they all had three: Distributor, Manifold, and Carburetor Port.
MDchanic is offline
Old October 29th, 2014, 04:05 PM
jerseyjoe's Avatar
Thanks guys. I know the later models run full advance but it is running just to rich at idle. Can't seem to get a great idle out of it and you can smell it is running rich. I will bypass for now and see if I can get it to idle better before buying a new switch.
If I recall the eighty's model years had two stems. Maybe to control EGR?
Old October 29th, 2014, 06:20 PM
I thought so too, but the one on my engine has two plus the fitting at the top. My old one has three plus one on top.
Old November 2nd, 2014, 02:22 PM
jerseyjoe's Avatar
Well being the dumb a$$ I am I should have checked the valve long before now! Put the new valve on today and it is a totally different car! Can anyone guess why? I cannot believe I did not realize this before, geez getting old
Mongoose
March 24th, 2014 01:54 PM
bornwina
March 24th, 2013 04:21 PM
Rob delta
January 31st, 2012 02:43 PM
dan1s
February 18th, 2008 11:41 AM
ct1979
December 22nd, 2006 10:22 PM
Quick Reply: Thermal Ported Vacuum Switch
