swap meet 350 build.
Old March 29th, 2013, 02:22 AM
  #121
DoubleV's Avatar
Good luck. With your heads done by Rocket Racing, you're going to need it! Hopefully everything works out.
DoubleV is offline
Old March 29th, 2013, 04:16 AM
  #122
Chevy budget Olds powered
coppercutlass's Avatar
I already ran them once on a previous combo worked great !!!!!!!!!!!!!! There is about 1100 into my heads alone it has big stainless steel valves, bigger springs, and rocket racing even did the bowl worl for free : )
coppercutlass is offline
Old March 29th, 2013, 04:40 AM
  #123
DoubleV's Avatar
That's good news. My #7 heads on the other hand which were done by RR ( which came on the engine they also built ), consisted of having only some of the valve guides done even though I payed to have them all done. The guides that were done, were installed crooked so my valves wouldn't seal. I was also supposed to have bigger valves, but they never put them in ( though I wasn't charged for them ). Same thing with hardened exhaust seats. Let's not forget the 3 angle performance valve job I was charged $200 for that was never done either. But hey, at least they screwed me over on my final compression ratio too which was supposed to be 8.8 but measures out to only 8.1 or so. John Stolpa now avoids me when I try contacting him because he knows he screwed me over, he knows that I know he screwed me over, and doesn't want to make it right. He is a liar, a crook, and a coward. But this thread is not about this, so I will leave it at that.
DoubleV is offline
Old March 29th, 2013, 04:48 AM
  #124
Ehhh. That's why I build my own stuff. I have never had issues with john. His prices are a bit steep sometimes on parts but usually he has what I need in stock. He has built 2 sets of heads for me and he built the trans I'm running.
Old March 30th, 2013, 09:27 AM
  #125
It's in it's in it's in finally !!!!!!!!!!!!! I hope my patience will pay off. I got it installed in just over 6.5 hours that removal and installation. It's all ready to go all i need is fluids, prime the oil system and stab in the dist. Im waiting till next weekend. My dad can help me fire it up and i dont trust anyone but my dad to fire uo my new engines as he already knows the routine since he always helps me.
Old April 4th, 2013, 06:47 PM
  #126
Ok guys just a mini update. I added coolant and oil. I primed the oil system and we have oil to the top end. I will re prime tommorow before initial start up and cam break in. I have no leaks and all systems are go !!!!!!!!!!!!!!!!
Old April 5th, 2013, 07:02 PM
  #127
If anyone cares . IT RUNSSSSSSSSSSSSSSSSSSSSSS !!!!!!!!!!!!!!!!!!!!!!! video to come soon
Old April 5th, 2013, 07:05 PM
  #128
https://www.facebook.com/#!/photo.ph...type=2&theater
Old April 5th, 2013, 07:12 PM
  #129
The only issue i have is the leaky intake at the rails. It leaks oil. Im going to smootch it for now with black rtv. If that dont work i found a place that sells cork gasket material and im tempeted to make my own rail gaskets from it . I think i didnt apply as much silicone as i should have.
Old April 5th, 2013, 07:22 PM
  #130
Alright!
Keep us up to date, Copper!
MDchanic is offline
Old April 5th, 2013, 07:27 PM
  #131
Thanks eric. The intake is no big deal. A few hours of busting @$$ and it will be fine. Im gonna mess with it tommorow and go from there.
Old April 5th, 2013, 07:34 PM
  #132
Congrats, sounds good.
oldcutlass is online now
Old April 5th, 2013, 07:45 PM
  #133
joesw31's Avatar
Copper, great to hear it running!
joesw31 is offline
Old April 6th, 2013, 09:51 AM
  #134
Drove it today. Mannnnn this thing has some giddy up !!!!!!! Didn't get into it too much but it's much better than the last set up. I'm gonna fix the leaky intake and it's all set.
Old April 6th, 2013, 11:04 AM
  #135
joesw31's Avatar
Great to hear it! When does the quarter mile open for you?
joesw31 is offline
Old April 6th, 2013, 11:11 AM
  #136
It's already open. But if all goes good end of this month for some time runs. The car runs very strong with the current tune so that will be my base line.
Old April 6th, 2013, 11:24 AM
  #137
Bernhard's Avatar
Congrats I hope it puts down some good numbers
Bernhard is offline
Old April 6th, 2013, 01:30 PM
  #138
Thanks I'm lookin for just a 12.9. Anything faster is even better. The limiting factor might be the carb to some extent. I'm running a 650 holley dp some guy say 750 3310 will work better. I have a line on a 770 street avenger but if I hit 12's with this set up I'm not gonna mess with it.
Old April 6th, 2013, 02:57 PM
  #139
TripDeuces's Avatar
Sounds good
TripDeuces is offline
Old April 6th, 2013, 04:09 PM
  #140
Thanks tripdeuces
Old April 8th, 2013, 07:36 PM
  #141
deejai35's Avatar
Glad to see its running. I need to catch up. Still pretty far behind. Once I get my q-jet running I will have a Holley 750 DP for sale. Too much Carb for my setup.
deejai35 is offline
Old April 8th, 2013, 08:37 PM
  #142
Thanks deejai35 . Just got done taking the intake off to fix the leakt end rail situation .
Old April 20th, 2013, 03:35 PM
  #143
Ok guys. Just a little update. I got the intake gasket issue fixed., no more oil leaking. I put new oil in it and a filter and put some fresh 93 in it. Man this thing has some throttle response !!!!!!!!!! I left the gas station and just bliped the throttle and i had them spinning instantly. I didn't stay in it long but the power this combination makes. Atleast on the butt dyno is much beter than my old 350 combo and all i did was go .030 and bigger cam. It also runs supper smooth the idle is choppy but the engine does not shake a whole lot and while crusing it's just smooth. Im hoping to take out tommorow again for a little longer drive once i fix my leaky oil sending unit leak. Just need a new compression fitting sleeve and im good. So far so good. the more i drive it the longer the drives will be this one was just a little 20 minute drive around town. i still have to make sure nothing else leaks and make sure it wont leave me on the side of the road. Hopefully in a month or so we will have some 1/4 mile times to post up.
Old April 20th, 2013, 04:54 PM
  #144
Good deal well done!
Old April 24th, 2013, 07:11 PM
  #145
1BOSS83's Avatar
Guys have ran mid 15's mostly stock, with 5A 307 HO Hurst/Olds and 442's. I know one non 442 running 15.2's, close to stock, mild cam and Sanderson's. Mid 14's on the computer has been done. I am hoping to pick up a 87 442, maximize the swirl port turd with bolt on's, 15 flat would be cool. Then build my 424 ci stroker and really kick but. No more exploding 7.5" rears.
15.3@ 91mph 83 H/O on a hot summers night only mod was headers
1BOSS83 is offline
Old April 24th, 2013, 07:13 PM
  #146
I never did get the chance to get the 307 to the track. It needed a rebuild as it was max oil psi was 25 while crusing. I did manage to beat a mid 70's corvette up untill i ran out of steam somewhere between 4000 rpm and it fell flat on it's face lol. Now time to get back on track with the 355 .
Old April 29th, 2013, 10:43 PM
  #147
VinMichael's Avatar
Nice work dude. I watched the vid and the engine sounds mean. This is really inspirational for me because I'm about to start a budget 350 build. Mine is gonna be really ghetto, but I want it to run hard.
Those are impressive ET's btw, way more than I ever achieved with my SBO
VinMichael is offline
Old April 30th, 2013, 09:41 AM
  #148
Thanks it took some time but I didn't break the bank.
Old May 15th, 2013, 05:52 PM
  #149
yankees's Avatar
Copper any track times yet?
yankees is offline
Old May 15th, 2013, 06:04 PM
  #150
Not yet. I have been driving it a lot. No leaks no weird noises. I'm thinking end of this month or early june depending on the money and time.
Old May 20th, 2013, 06:15 PM
  #151
Track times will have to wait for a few more weeks than expected. On a good note my friend stopped by and let me have his near new 750 holley 3310 for 75 bucks so i have a diffrent carb to test out. Been enjoying the good weather and hanging out with old friends driving the car.
Old June 15th, 2013, 11:26 AM
  #152
well times will have to wait yet again. I installed a new flexplate as the one I had was bent. Since im down there im going to change to new to me headers and do some exhaust work since I extended the collectors. Im also going to do suspension work before I hit the track the car needs it along with new front tires. But the engine is still running very very strong. No issues no alarming noises besides maybe bad trans / flex plate or possibly a hint of detonation once I out the trans back in im adding 8 gallons of 110 Sunoco.
Old June 15th, 2013, 04:19 PM
  #153
I hope I got it worked out. I may have to still possibly put in a new trans. But since im trying to rule things out the old one has to go back in.
Old July 6th, 2013, 11:37 AM
  #154
Well I thought I would follow up on this thread I know a few people wanted e.t.'s. Well life seems to be getting In the way. I have been driving my car and doing all kinds of repairs as well. I put in a new flex plate. My old one was wobbly. I finally found that grinding noise in the top of 3rd gear I think it's my drive shaft or trans. I ruled everything else out. Other than that the engine has been running really good.
Old October 27th, 2013, 06:25 PM
  #155
I still have not forgotten about this thread. E/T's for this season will have to wait I decided to get some other things in order for safety's sake. I did all new suspension, doing some new safer fuel lines , finishing my rear firewall, and im improving my cooling system as the car ran cool while driving but not enough flow at idle, I also rebuilt a th350 that's going in pretty soon. Im going to a th350 from a 400 in an effort to free up some ponies, . Although im bummed out I got no track time as this will be season number 2 I sat out and I wont be able to get some baseline numbers . Im happy to say the engine runs well, No noises no smoke , no major leaks, . Hopefully by next april when the track opens I will be ready and all set to go with nothing left to do but enjoy it and race it.
Old August 23rd, 2015, 08:30 PM
  #156
Well. Its been a while but this build finally saw the track. A few things changed like the cam . but nothing major. Off the trailer with no tuning and a carb stumble we went 13.09 @ 103 mph . Not too shabby for a little swap meet build that even after addressing a cam issue that was eating the bearings and buying a new timing set still cost appx 4k . just thought i would bring this thread to an end.
Old August 25th, 2015, 07:52 PM
  #157
deejai35's Avatar
Nice! Glad you got everything ironed out. I am very happy with my budget build as well. I hope to get some dyno numbers in the near future.
deejai35 is offline
Old August 25th, 2015, 08:14 PM
  #158
Thanks. 12's are in the near future with a few changes i have made. After that we will swap to fully ported heads to see what gains we will see.
banny
April 27th, 2023 01:03 PM
oldsonharmont
January 10th, 2009 08:49 AM
The Stickman
November 30th, 2008 05:20 PM
74omega
August 7th, 2008 01:26 PM
leadfoot067
February 23rd, 2007 04:21 AM
Quick Reply: swap meet 350 build.
