Ram Rod 350
Old July 12th, 2008, 10:23 AM
72 Supreme's Avatar
Ram Rod 350
Does anyone know anything about these set ups like was the intake cast iron or aluminum, valve specs and cam specs,size of exhaust manifolds. Any info would be appreciated.
Doug.
72 Supreme is offline
Old July 12th, 2008, 01:50 PM
Doug.
The 68 Ram Rod 350 (and identical 69 W-31) used the same heads and cast iron intake as all other 350s in those years. The heads had the 2.000/1.625" big block valves installed. The 308 deg cam used in earlier W-30 motors was used in the 68-70 small blocks. Exhaust manifolds were the same as used on all other 350s, complete with a cap on the crossover port on the RH manifold.
joe_padavano is offline
Old July 12th, 2008, 06:28 PM
Senior Moment Member
z11375ss's Avatar
These cars came with a 3 or 4 speed only. A special harmonic dampener was also used. I have a cloned one in the section Well here it is! Located down the small block page. Take a look it's pretty cool. Mine has incorrect red fenderwells. They should be black but they came with the car and I just couldn't take em out.
z11375ss is offline
71HolidayCutlass
November 9th, 2018 06:14 PM
jaydc68
September 16th, 2013 08:21 PM
'S'tuff1979
September 25th, 2012 08:25 AM
'S'tuff1979
September 24th, 2012 06:24 PM
442ric
May 30th, 2011 07:27 PM
Quick Reply: Ram Rod 350
