not enough air comming thru fan ?
Old June 17th, 2011, 06:23 PM
knighthawk's Avatar
Location: from Wisc, then Texas, then Kansas, now back to Texas,
69 Cutlass 350 2bbl, small cam , etc , problem; overheats when ever it's not moving. I thinking , not enough air being pulled thru the rad at idle....so...The fan is a 6 blade, 17 or 17 1/2'', the shroud (original, I think ) has 1'' clearance on one side, 2'' clearance on the other, .....another thing I notice, the water pump pully is about 7'', while the one in my '67 Toro (with the 425) the pully is about 6''. How does all this compare with what you guys have ?
knighthawk is offline
Old June 17th, 2011, 06:31 PM
How's the fan clutch?
MDchanic is online now
Old June 17th, 2011, 06:54 PM
knighthawk's Avatar
no fan clutch
allyolds68
February 9th, 2013 08:01 PM
442NDTSS
August 3rd, 2012 02:30 PM
oldsatheart
August 17th, 2011 07:39 PM
1973olds98
Ninety-Eight
19
October 25th, 2010 04:40 PM
jojo66
April 29th, 2008 12:22 PM
Quick Reply: not enough air comming thru fan ?
