need help with crank bearings for rocket 350
Old December 19th, 2006, 08:09 PM
olds350's Avatar
hi i am rebuilding my 1969 350 rocket engine right now and after looking at the main bearings i see that one of them has no groove are hole. and im wondering where this bearing belongs.i would think the only place it would belong is in the back of the engine but i want to no forsure.
~kirt
olds350 is offline
Old December 20th, 2006, 01:55 PM
Oldsmaniac's Avatar
The front bearing has no groove....the rear is wide and the one for the cap that the oil pump bolts to.......It is double grooved......the center is the thrust bearing that overlaps on the sides to keep the ctank from moving back and forth.
Oldsmaniac is offline
Old December 21st, 2006, 05:11 PM
olds350's Avatar
thank you very much
olds350 is offline
billmerbach
June 11th, 2014 03:49 PM
Bobac455
May 27th, 2011 07:03 AM
sx455raidercelticfan
November 23rd, 2010 05:45 AM
oldzy
Drivetrain/Differentials
September 14th, 2010 05:40 AM
Quick Reply: need help with crank bearings for rocket 350
