Keep the EGR Valve or not?
Hey guys,
Looking for suggestions. I have a 1976, Cutlass w/350, 4BBL Rochester, 49K orig miles. The car sat in a garage since 1985 until I purchased it this past spring. I've been tweaking the engine most of the summer & trying to get the final quirks out of it. I rebuilt the carb, replaced the ignition wires, plugs, Dist cap, rotor button, coil, ignition module & vacuum lines. Would you guys recommend blocking off the EGR valve to improve vacuum to the carb or leave it connected.
Thanks in advance for the help,
Chris
Chris
Hey guys,
Chris
Chris
Thanks Joe,
I figure I'll play with it both ways & see what happens. Since it's not WOT all the time, I would prefer the extra MPG if it truly does help. I have not replaced the thermal port switches as they seem to be functioning ok.
Kidcutty
July 13th, 2010 05:06 PM
