Intake/Exhaust Valve question
For my winter beater, I'm doing an extreme budget rebuild on a '75 350. I know that much for sure due to running the block numbers. It is not the original engine to the car and I'll also add that this is my first engine rebuild.
I'm confused on the valves in the heads. I have the 411929 Type 8 heads which jive with the dates on the block.
While lapping the valves and installing new valve guide seals, I discovered a bad valve. It's flatspotted on one edge instead of round. I'm trying to find a replacement for it.
Visually, it's the smaller of the two valves for that cylinder. To me, it looks like it should be the intake valve. But now I'm not so sure after seeing this chart. (POST #4)
https://classicoldsmobile.com/forums...tml#post180704
On the chart, it lists all of the intake valves as being larger than the exhaust. The part in question measures a little over an inch and a half. NAPA says the intake valve would measure more like 1.8" which the chart also confirms.
Can someone please clarify this for me. Is it the EXHAUST valve I need or the intake? I know it's likely a newbie question. But I appreciate any responses.
A quick way too see is look at what port it came from intake or exhaust. I have a bunch of #8 valves if you need any. Or atleast I think I do. If you are intrested let me know and I'll look in my parts bin. Intake is bigger.
svnt442
July 17th, 2011 04:43 PM
