HELP!!! no fuel going to carb and im stranded!!!
Old June 11th, 2016, 06:35 PM
  #41
Gary M's Avatar
I would buy the game camera, a new fuel tank, locking cap, flush the lines, a new fuel pump and filter. Oh yea - some glass pack mufflers just for good measure. Put the camera where it can't be seen call police and press charges when you get evidence. I've had this kind of thing happen and once you establish with law enforcement what is going on it will stop.
Gary M is offline
Old June 12th, 2016, 12:06 AM
  #42
Gearhead in training
Northern Custom Cruiser's Avatar
Originally Posted by Octania
"Don't let them tell you that you need the high pressure EFI rubber line. You don't."
On the suction side of the pump... I should say you don't need high pressure line, no.
Carefully remove the steel line you show from the pump. Loosened at the top is not a bad idea either. A crowfoot line wrench does wonders for these jobs.
6-pt is less likely to round the line nut. Can be used at the carb too. 5/8"
http://cgi.ebay.com/ebaymotors/SnapO...0AAOSwZQxW5NUY
Interesting but the job seems to be done! I did round the line nut a bit, but thats because after i gor everything together i was leaking gas from the top of the line by the filter and i had to lossen and retighten some things. The car drove beautifully afterwards so i think that was the isssue. Thanks so much guys!
Northern Custom Cruiser is offline
kartmaster
September 14th, 2012 12:55 PM
Somwan
Suspension & Handling
June 13th, 2012 04:36 PM
navvet
April 20th, 2011 06:42 PM
442much
February 2nd, 2011 08:16 AM
dhowe
December 29th, 2007 12:56 PM
Quick Reply: HELP!!! no fuel going to carb and im stranded!!!
