Heads
Old November 22nd, 2016, 05:18 AM
Pfiffle's Avatar
Heads
I have a 1976 Cutlass 350. Im on a tight budget as many are these days. Would I be better off Milling/valve job on my factory heads or finding a set of 68-70 heads and rebuilding them to bump compression. What would be the best bang for my buck? Might be a stupid question but I come here for advice from more knowledgeable people.
Tom
Pfiffle is offline
Old November 22nd, 2016, 07:16 AM
72 Olds CS
RetroRanger's Avatar
68-72 heads are about the same chamber size
if you have to remove your heads mill them and rebuild them, VS rebuild 68-72 heads that you need to purchase then ship its gonna be close as 350 head cores are generally $100-200 plus shipping which is $50-200 depending on how close you are to the shipper.
if your car is on the road i would try to find some 68-72 heads local to you and then have them rebuilt and swap them out. if your lucky you may find some close that have been rebuilt or on a running engine,,,then you could jusr swap them.
so in short location may help here
RetroRanger is offline
Old November 22nd, 2016, 07:41 AM
damaged442's Avatar
There is really more to the question. What kind of performance are you looking to get or gain by doing or swapping the heads? How will you be driving it?
What rear is in the car? Head work might not get you the gain you seek, if you still sport the standard 2.41s, and might pretty much be a waste of funds...
damaged442 is offline
Old November 22nd, 2016, 08:04 AM
Proud Viet Nam Veteran
redoldsman's Avatar
The 72's and I believe the 71's have hardened valve seats which is something to consider if you do decide to change heads.
redoldsman is offline
Old November 22nd, 2016, 09:49 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Keep an eye out for deals. I got a set of rebuilt #6 heads for $400 off Kijjii. They have 2.07/1.56 valves, measured with my caliper and the chamber CC at 62 to 64cc. Supposedly $1200 spent on them, going to pull a couple valves and measure and the center exhaust guide clearance and see if proper guide work and valve job was done. I find most #8 heads CC at 77-78. Early heads CC usually around 68-70CC, so with a reasonable mill, say .020", depending on where they CC, bring them to 64cc. With your current short block and .028" Rocket racing head gaskets, you should be right around 9 to 1 compression.
olds 307 and 403 is online now
Old November 22nd, 2016, 10:48 AM
Pfiffle's Avatar
damage, I installed a posi 3.73 rear built for me by JD Racing. I drive it locally on nice days. Not looking for a beast but more "pop". Kijji? Thats a website? Will check that out, olds 307. 9 to 1 would be good. 9.5 better, ha. Have a set of thornton manifolds to be installed for true duals. redoldsman, thanks. I did not consider that. This is why I came here. I suppose a cam change will be required also. Lots of good info already. Thanks.
Pfiffle is offline
Old November 22nd, 2016, 10:52 AM
Pfiffle's Avatar
Im also planning on installing a rebuilt Qjet to replace the Holley. Holley has an electric choke. Dont know whats involved in the swap. That will be another thread, I guess.
Pfiffle is offline
Old November 22nd, 2016, 11:05 AM
That probably depends upon what intake manifold you have - square flange or spreadbore mount. If it's a spreadbore mount, then all you likely need is fuel line and throttle cable modifications.
Fun71 is offline
Old November 22nd, 2016, 11:09 AM
Pfiffle's Avatar
It looks like the factory intake. OK. Doesn't sound too bad.
Pfiffle is offline
Old November 22nd, 2016, 12:48 PM
A cam change is necessary, the stock one is pathetic. I would go with one like Fun71 is running.
Old November 22nd, 2016, 05:25 PM
Oldcoyote's Avatar
I give, which cam is that?
Oldcoyote is offline
Old November 22nd, 2016, 07:52 PM
brownbomber77's Avatar
Where are you located? I have put a few sets of 330 heads on late 350s with great success. Just drill out the head bolts to 17/32 so you can use them. Also, put in 2.07/1.68 valves. Gives ya room to grow if you want to. That stuff is a good start if you're doing heads
brownbomber77 is offline
Old November 22nd, 2016, 08:32 PM
Look in my signature line.
Fun71 is offline
64 CUTLASS KEN
December 7th, 2020 06:43 AM
olds4life
December 25th, 2012 12:56 AM
Oldsmaniac
November 1st, 2010 06:37 PM
gearheads78
November 10th, 2009 09:31 PM
DarkStar
October 21st, 2009 07:35 AM
Quick Reply: Heads
