Distributor won't come out? 1970 350
I am having trouble removing the Distributor on my 1970 olds Cutlass 350 (66K) original miles i have the engine out tearing it down to repaint and freshen up the externals.
My question is this the Distributor will not come out?
- Distributor hold down removed
- Oil Pump and rod removed
- Spins with cam just fine
- it moves up and down in its boss about a 1/16 but will not come out?
Thanks everyone, I used the old pry bar under the Dist technique, it popped out after a disturbing amount of force and the rubber o ring was dry most likely a side effect of not being driven much. a lil white lith grease and it fits and removes like new now.
