Decent HEI replacement for 350 rocket.
Old December 17th, 2016, 09:54 PM
RetroResto's Avatar
I'm going from points to HEI on my 71 350.
What would be a good go to NEW distributor, that is not over priced, but not too cheapo, and something I would easily be able to grab replacement parts (module) for?
I need it to be reliable as I will be driving the **** out of this car.
RetroResto is offline
Old December 17th, 2016, 10:13 PM
Oldsmobile enthusiast
s i 442's Avatar
I have bought several of the Ebay ones without problem, they have a fast and usable curve in them . Im not spending $500 on a name brand that does the same thing. If anything buy the cheap one for all the components and buy a module of you choice.
s i 442 is offline
Old December 17th, 2016, 10:41 PM
RetroResto's Avatar
So just to be clear are are off the shelf modules compatible with the CHYNA/eBay distributors?
I don't need anything special I just want to be able to have a spare on hand or readily available.
Old December 18th, 2016, 04:01 PM
Olds442redberet's Avatar
I just bought an older mallory unilite off ebay for $90.00. I am replacing the pertronics i am currently using.
Olds442redberet is offline
Old December 18th, 2016, 06:07 PM
Chevy budget Olds powered
coppercutlass's Avatar
I have been running one of those ebay china hei's in my dad's olds powered pontiac for 6 years now no issues. I have been running my proform HEI for over 8 years and no real issues. Until recently so i think its time for a new one.I got my moneys worth imo.
coppercutlass is offline
Old December 18th, 2016, 07:48 PM
Oldcoyote's Avatar
I have been using this one for many years on my 403. They customize the advance curve.
http://performancedistributors.com/p...i-streetstrip/
Interesting info on their web site.
Oldcoyote is offline
Old December 18th, 2016, 08:08 PM
Thats actually what im buying next.
Old December 19th, 2016, 06:28 AM
I stand behind the Summit distributor in my 71 98.
https://www.summitracing.com/parts/s...ake/oldsmobile
I had to put a module in it from O'Reillys after about 2 years of use. When it needed the new module I went ahead and used a timing recurve kit to dial it in.
Don't let the fact that it's Chinese worry you. We watch TVs and use computers every day of our lives that were built in China.
Olds64 is offline
Old December 21st, 2016, 04:01 PM
'72 Cutlass ragtop
70sgeek's Avatar
Pertronix Flamethrower III is what I installed on my '72 350 - it's the points style cap so small enough to provide firewall clearance and simple hookup. runs about $225 or so. Only have a few hundred miles on the fresh motor build but so far no issues.
70sgeek is offline
Old December 21st, 2016, 04:05 PM
RetroResto's Avatar
Is clearance an issue with larger HEI type cap with coil built in?
Old December 21st, 2016, 04:52 PM
'72 Cutlass ragtop
70sgeek's Avatar
I think there's clearance, but not sure how much - I know it's somewhat tight for the original points style distributors and the later-style HEI cap bodies are bigger.
the Flamethrower HEI retains the point-style cap so I decided on that to keep things simple
70sgeek is offline
Old December 21st, 2016, 05:03 PM
Proud Viet Nam Veteran
redoldsman's Avatar
The larger HEI will fit. I have one in my 72 Cultass.
redoldsman is online now
Old December 21st, 2016, 05:09 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Doesn't the factory air cleaner hit the large cap HEI?
olds 307 and 403 is offline
Old December 21st, 2016, 05:32 PM
redoldsman's Avatar
You are correct about the air cleaner. I forgot that. I just used a spacer between the carb and air cleaner.
Old December 21st, 2016, 05:49 PM
Be aware that points replacement conversions are not the same thing as HEI.
Fun71 is offline
Old December 21st, 2016, 08:10 PM
The ignitor 3 ready to run is supposed to be sort of multi spark and uses the hall effect pick up.
https://m.summitracing.com/parts/pnx-d7110711
djchunter
March 17th, 2016 03:57 PM
joepenoso
June 4th, 2014 01:56 PM
Archer Meredith
October 30th, 2013 06:37 PM
coppercutlass
October 27th, 2012 01:16 PM
oldscruiser
February 15th, 2011 12:44 AM
Quick Reply: Decent HEI replacement for 350 rocket.
