Cam Profile for 350 Dual Quad Set Up
Old December 12th, 2015, 01:13 PM
jbarnett's Avatar
Hi guys,
I have a 69 Cutlass that I am thinking of doing a dual quad setup on. I know the single 4 is usually the best way to go for a street motor but thought this could be worth the cool factor and have some get up.
Motor is a 69 350 with #5 heads, stock. It has 1 5/8th's headers. It was rebuilt at some point but I don't know anything about it. It runs well and has some grunt but doesn't feel like a high compression, nearing 10 to 1 type motor. TH350 trans with 12 bolt Olds and 2.73's I think.
Trans leaks so I am getting that fixed so I can go with a higher stall converter and I want to put 3.08 or 3.23 posi gears in it.
But the big question is that if I went to an Offy dual quad set up with 2 500cfm Edelbrocks what kind of cam profile should I go with? I want to keep using the power brakes and steering but I'd like a cam that works great with the combo but also has a noticeable idle. I searched the forums but I didn't find anything relating to cam choices for this combo and even less info on it for a SBO. I have a set of roller rockers that I'll do with the cam change.
J
jbarnett is offline
Old December 12th, 2015, 01:28 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
You will need to figure out the compression ratio, was it two or four barrel originally? I would go with the AVS version or even better dual Street Demon 625's. There is an ultra low profile dual quad and a taller version. I would defintely use 1" or 2" phonelic spacers on the intake with Edelbrock carbs. I considered one for the cool factor.
olds 307 and 403 is offline
Old December 12th, 2015, 01:48 PM
captjim's Avatar
Originally Posted by jbarnett
Hi guys,
J
If it has been rebuilt and the pistons replaced, all bets are off. Your CR could be as low as 7.5 to 1 or as high as 10 to 1. Putting a dual quad high rise on a low comp small block is a recipe for a turd with no bottom end. As 307/403 recommended, you will need to determine the true CR and go from there. I like old-school cool stuff, but if you end up spending a bunch of money on something that is no fun to drive, what is the point? You also do not know what cam is in it.
captjim is offline
Old December 12th, 2015, 01:59 PM
jbarnett's Avatar
True enough. Throwing money at something to not get what you want sucks.
It doesn't have a very radical cam and I know it's hyraulic. It reminds me of how this old SBF sounded and idled with a Comp 260 in it. I know that's apples to oranges but this is mild cam from driving it.
For the sake of argument let's say the motor is 9 to 1. I'll get it checked at some point before moving forward but I'd like to get dialogue going at any rate.
J
jbarnett is offline
Old December 12th, 2015, 02:49 PM
captjim's Avatar
J
IMHO if it truly is 9 to 1 you are not going to make it work.
captjim is offline
Old July 11th, 2017, 03:33 PM
jbarnett's Avatar
Went a different route here but the info was useful.
J
jbarnett is offline
jcdynamic88
November 7th, 2015 11:25 AM
1966g10
February 27th, 2014 12:38 AM
1966g10
December 8th, 2013 04:40 PM
bccsrc
January 30th, 2008 07:22 AM
Deltarocket
February 16th, 2007 12:04 PM
Quick Reply: Cam Profile for 350 Dual Quad Set Up
