bad exhaust valve
Old February 21st, 2022, 12:10 PM
  #41
deadeyejedi's Avatar
i tried a video of this motor running when i first got it.
deadeyejedi is offline
Old February 21st, 2022, 01:31 PM
  #42
Out of Line, Everytime😉
olds 307 and 403's Avatar
Great oil pressure at that temp. Makes a good back up motor if nothing else.
olds 307 and 403 is offline
Old February 24th, 2022, 03:38 PM
  #43
While on hold from the machine shop ive had the opportunity to clean up and do some painting on this bastard 350 . she's starting to grow on me!And yes a red fan blade why the hell not
Old February 24th, 2022, 03:39 PM
  #44
Old March 1st, 2022, 03:44 PM
  #45
Probably build a whole car by the time those heads come back.
Old March 17th, 2022, 11:55 AM
  #46
Got the heads back from the machine shop . Ended up only needing the one guide all else spec’d out they glass beaded the heads polished the valve stems and lapped all the valves replaced the valve retainers and replaced the one bad exhaust valve. Will start putting things back together this weekend after some fresh paint .
Old March 17th, 2022, 01:42 PM
  #47
Sugar Bear's Avatar
Do you know what valve stem seals were installed?
Good luck!!!
Sugar Bear is online now
Old March 17th, 2022, 02:13 PM
  #48
Good luck!!!
looks like the regular umbrella seals to me.I do not know the brand
Old March 17th, 2022, 02:51 PM
  #49
these seals look like the felpro seals I wonder if I should just replace them now they are the ones that were on the heads so not new . What would a good seal to get without having to do machine work ?
Old March 17th, 2022, 03:16 PM
  #50
Sugar Bear's Avatar
I would ABSOLUTELY start with new seals. Someone will chime in...I think there are positive lock seals that work without machining.
Good luck!!!
Old March 17th, 2022, 03:19 PM
  #51
Good luck!!!
would be easy enough to do now not in a hurry to put it back together
Old March 17th, 2022, 03:21 PM
  #52
Loaded68W34's Avatar
I have used these on my last few engines. Did not even know they existed until I got this set of heads back from my machine shop with these installed. Fit over guides with no machining and have a small spring to keep a tight seal around the valve stem.
Loaded68W34 is online now
Old March 17th, 2022, 05:40 PM
  #53
Those look nice, post a part number on those positive seals. Most common positive seals need the guide machined to fit properly. Looks like this 350 will make a nice running motor.
Old March 17th, 2022, 05:48 PM
  #54
Don't have a part number. I had to look them up by valve stem diameter as I could not find them listed anywhere for an olds or pontiac (last 3 engines I put them on: 68 olds 445, 68 olds 455, 67 pontiac 400).
Old March 18th, 2022, 07:30 AM
  #55
Old(s)GuysRule
67OAI's Avatar
The factory type valve stem oil seal is a "shroud" type of device which keeps oil from splashing directly onto the valve stem but allows the mist of oil inside the valve cover to provide some lubrication to the valve stem and guide. Over the years, the seal material has been refined and current replacements are a plastic type material. The seal fits tightly on the valve stem and locates itself on the valve stem upon initial engine start. I highly recommend the use of the stock factory type valve seals on any stock or near stock rebuild. On my personal vehicle, '67 W30, I use the shorter exhaust valve seal on the intake and no seal on the exhaust; the motor does not use oil.
67OAI is offline
Old March 18th, 2022, 08:08 AM
  #56
BillK's Avatar
The factory type seals are fine. Oldsmobiles dont seem to have a problem with oil consumption from that area. The 307 in my Wifes Riviera never used a drop of oil and it went 250K miles before the timing gear gave it up. When I rebuilt the engine I just put the factory type seals back on and it has been about 5K miles and it has not used a drop.
BillK is offline
Old March 18th, 2022, 08:51 AM
  #57
SOLD!!! Thanks Bill
Old March 18th, 2022, 09:58 AM
  #58
I couldn't agree more, my 307 used/leaked a half liter oil at 450,000 km. I had all the bills from when the car was bought new in 82, no major work. I like Oldsmobile V8'S because they were the best from the mid 70's till the mid 80's for reliability.
Old March 21st, 2022, 05:55 PM
  #59
getting dam close to firing this old girl
Old March 21st, 2022, 06:06 PM
  #60
66SportCoupe's Avatar
What's up with the oddball valve cover on the drivers side? Looks great otherwise.
66SportCoupe is online now
Old March 21st, 2022, 06:33 PM
  #61
The valve covers were pretty rough so it has a 455 cover on one side . Good catch ! I have some real nice ones still not sure what I’m going to do with thing
Old March 21st, 2022, 06:48 PM
  #62
If you need early valve covers let me know. I have 8 sets
Old April 8th, 2022, 05:05 PM
  #63
https://youtu.be/8YN_tqLopVE
louie
March 4th, 2020 04:27 PM
Kaktus
February 3rd, 2020 06:56 AM
firefrost gold
May 16th, 2015 04:47 PM
ramos7
September 2nd, 2009 11:58 AM
BosMobile
May 22nd, 2009 05:03 PM
Quick Reply: bad exhaust valve
