76 350 Shuddering/Jerking when Accelerating
Old August 30th, 2019, 02:04 PM
bwh69s's Avatar
I have same problem as 76Cutlass 442 had in 2015. My 69 Cutlass S has an HEI with a Mallory 6A ignition control box. Car starts and idles no problem, but shudders when I try to accelerate. I changed the fuel pump and distributor pickup coil with no luck. I pulled the vacuum hose off the distributor, plugged the hose and rev'd the engine and it runs fine. WTF? Could my vacuum advance canister on the distributor be bad? What else could be causing the problem?
bwh69s is offline
Old August 30th, 2019, 02:51 PM
I moved your post to its own thread, your issue is different. Was your advance hooked to ported or manifold vacuum, did you have to raise the idle speed when you pulled the hose off the advance? What is your timing set to? Is this a new install, or has it been running good up till this point?
oldcutlass is online now
Old August 30th, 2019, 03:09 PM
FN723's Avatar
Sounds reasonable the problem might be the vacuum advance. Hook up a hose to it and blow or suck into the hose. If it's bad you shouldn't be able to get any air through it.
FN723 is offline
Old August 30th, 2019, 05:29 PM
Sugar Bear's Avatar
Try driving it with the vacuum advance hose plugged and see how it runs. I've read that you replaced pickup coil; but, no issues with the vacuum advance plugged is usually a bad pickup coil/pole piece in the distributor. It could be a "notching or binding" vacuum advance.
Good luck!!!
Sugar Bear is offline
Old August 30th, 2019, 05:55 PM
The entire car shudders or the engine shudders, or both?
Vintage Chief is online now
Old August 31st, 2019, 05:55 AM
bwh69s's Avatar
Thanks for so many responses so quickly. Here's some additional info:
- I can't remember when last time car ran properly, been down for a few years (3 or 4) due to other priorities and other issues - exhaust, ignition, etc. that I finally fixed and am trying to make it road worthy again.
- Current timing set to 20 degrees BTDC (had it set at 10 degrees BTDC but had same shuddering issue)
- Vacuum advance hooked to manifold port at first, but moved to carb port (same problem either way)
- Engine idles slower with vacuum advance plugged
- I drove with vacuum advance plugged and car ran fine, but sluggish. It didn't have good pickup and shifted gears early (lower rpm)
- I watch the engine while I advance the throttle on the carb by hand and it will starts shuddering/shaking as I try to increase throttle
bwh69s is offline
Old August 31st, 2019, 06:18 AM
You do have both ends of the ATM (Automatic Transmission Modulator) vacuum hose connected with no apparent vacuum leaks in the ATM hose?
Old August 31st, 2019, 06:50 AM
Suspecting it’s one of three issues:
(1) Electrical - Coil windings not delivering required output as RPM advances (assuming timing, plugs, wiring, are correct);
(2) Fuel delivery - Carburetor A/F mixture screws are set for highest achievable vacuum and carburetor operation is nominal;
(3) Vacuum - Leak(s) in one, several hoses. Should be able to pull ~17.5” Hg.
Old August 31st, 2019, 11:19 AM
If it has old gas in it from sitting that could cause a lot of issues. If it runs better with the vacuum disconnected its probably because it needs to be limited to 10* with a stop. You need to put a timing light on it to see if your mechanical advance is working properly.
Old September 1st, 2019, 05:33 AM
bwh69s's Avatar
Ok, I determined the issue is most likely electrical/timing so I decided to take it back to a more simple set up to better isolate the problem. I completely disconnected the mallory ignition box and swapped the HEI distributor with my original distributor that has a pertronix kit to replace the points and condensor. Now, I can't adjust the timing below 30 degrees BTDC due to my vacuum canister on the distributor hits my intake manifold. Does this mean I might have jumped a gear on my chain?
bwh69s is offline
Old September 1st, 2019, 05:40 AM
No it means you installed the distributor wrong. You can pull it and rotate the rotor CW 1 tooth and readjust timing, or move the wires to the right (CW) 1 hole and readjust timing.
77ricbaez
July 21st, 2016 08:28 AM
s i 442
April 5th, 2015 07:11 AM
delta_88_germany
October 12th, 2013 11:35 AM
stlbluesbrother
October 7th, 2012 07:07 PM
al714
April 11th, 2011 08:15 PM
Quick Reply: 76 350 Shuddering/Jerking when Accelerating
