67C/S exh manifold gaskets
First question- I want to put the metallic sides towards the heads, is this correct thinking?
Just bought a set of Thornton JR exhaust manifolds for my 67 330, the ports are bigger than on the heads.
Second question, I have two sets of gaskets. One fits the engine heads and the other fits the larger ports on the exhaust manifolds.
Which one do you guys think I should use?
Since there were no gaskets there originally I would try without them, a gasket may not be needed and is something that will fail over time. You can always drop them in later if there is a sealing issue.
airvegas
March 28th, 2016 07:26 AM
