350 overheat
Old January 23rd, 2011, 07:25 PM
mryoung4815's Avatar
350 overheat
changed the plugs oil and filter put coolent tried to start it ran real bad and then turned off now it wont start at all i saw a fire ball come out of the carb when i put starting flued and gas in the carb my dad said its off timing i was wondering if i had to take the distributor bolt off does anyone know what size that is and its a 350 olds and i dont have a timing gun any help would be great
mryoung4815 is offline
Old January 23rd, 2011, 07:35 PM
Mingus's Avatar
Was it running before you did the work, or are you trying to get it running for the first time?
Mingus is offline
Old January 23rd, 2011, 07:38 PM
Rickman48's Avatar
Since you didn't turn the distributor, it shouldn't be the timing!
You've probably crossed the plug wires, and flooded it.
Check your wiring, and wait 'til tomorrow to start it!
Bolt is 9/16, just has to be loosened, but don't change anything w/o a timing light!!!!
Rickman48 is offline
Old January 24th, 2011, 07:19 AM
No after it overheated I got it started and it ran rough then died then I did the work and now it won't start it turns over and sounds like it wants to but it doesn't and its getting gas I can see it squrt maybe new wires since I changed the plugs two of them had the metal part that clicks stuck on the plug
Old January 24th, 2011, 07:23 AM
My dad also said that since it overheated it could jump timing so I don't know
Old January 24th, 2011, 01:42 PM
Rickman48's Avatar
If it jumped timing, you'll need more than plugs and wires!!
Pop the cap, watch the rotor as you turn the lower pulley - more than 2 inches play b4 the rotor moves, and you need a chain + gears, + + +!!
Old January 25th, 2011, 05:00 PM
Wyze's Avatar
I'd get new wires before I did anything else!!!!!!!
But bad wire aren't gonna make you run hot, just crappy or not at all!!!!!!!!
IMO!!!!!!
Good luck!!!!!!
Wyze is offline
Dto13
June 29th, 2014 06:03 PM
flatoz
May 9th, 2011 02:35 PM
nelsontj
June 2nd, 2010 04:58 PM
ztim
June 17th, 2008 09:30 AM
ztim
April 28th, 2007 03:52 PM
Quick Reply: 350 overheat
