350 GM Steel Shim Head Gaskets
I have a 350 build on the horizon and I have a set of GM steel shim head gaskets I want to use. What have you guys used on these to help seal, Copper Kote? Thanks
Clean your block and head surfaces very well with acetone or lacquer thinner and use the Copper Cote spray on both sides of the gasket.
