330ci 39 or 45 degree cam?
Old October 6th, 2015, 05:54 PM
willcynn's Avatar
THANKS , Willie
willcynn is offline
Old October 7th, 2015, 03:57 AM
cutlassefi's Avatar
What year?
cutlassefi is online now
Old October 7th, 2015, 04:46 PM
willcynn's Avatar
1965
willcynn is offline
Old October 7th, 2015, 05:12 PM
cutlassefi's Avatar
Should be a 45 then.
Old October 7th, 2015, 06:50 PM
svnt442's Avatar
I thought that was only with the big blocks and all of the small blocks have the same lifter bank angle.
But what do I know.
EDIT...
I knew I was full of it....lol
http://www.442.com/oldsfaq/ofblk.htm#Small Block Blocks 1964 - 1990
svnt442 is offline
Old October 7th, 2015, 06:52 PM
Oldsmaniac's Avatar
67's are supposed to have 39 degree cam angle, and I hope this is true as thats what went in my 330 on the stand still.
Oldsmaniac is offline
Old October 7th, 2015, 06:53 PM
therobski's Avatar
x2-CutlassEFI, WILLCYNN check out:
http://www.442.com/oldsfaq/ofeng.htm...964%20-%201990
arly: Late: 1964 thru 1967 1968 and up Big-neck PS pump Little 1" or so PS fill hole (1971+) Early pattern flywheel/flexplate Late pattern flywheel/flexplate SB's= 330 CID SB's= 260, 350, 307, 403 CID BB's= 400, 425 CID BB's= 400, 455 CID Block= A, B, D, or E Block= G, F, Fa Heads= A thru C Heads= C and up X/W or X/Y xst manifolds W/Z xst manifolds, if lucky Forged crankshaft Cast crank [99.9%] 45 degree cam required 39 degree cam required [except .921" lifter BB's] [all engines] No divided exhaust manifolds May have divided exhaust manifolds
therobski is offline
Old October 7th, 2015, 06:59 PM
therobski's Avatar
Oldsmaniac your good!!, Mark skipped a beat all is good!
Mr. King
November 16th, 2017 10:02 AM
scrappie
July 22nd, 2009 03:11 AM
jessejames
March 16th, 2009 04:46 AM
jdanieljones
December 28th, 2008 01:55 PM
DennisG.
June 14th, 2008 12:18 PM
Quick Reply: 330ci 39 or 45 degree cam?
