330 rebuild
Old November 22nd, 2011, 06:49 PM
optimus's Avatar
330 rebuild
hello everyone i need some help i am deciding wether or not to rebuild my olds 330 would it be worth it or should i get another motor any help would be appreciated thanks
optimus is offline
Old November 22nd, 2011, 07:04 PM
Rickman48's Avatar
Any Olds motor will cost about the same to build - cores are anywhere from $100 - $600, whether it be 350 or 455.
What are your intensions??
Rickman48 is offline
Old November 22nd, 2011, 09:32 PM
Redog's Avatar
The 330 is a pretty nice motor, if you have the hi compression "4" heads it has 10.25:1 CR right out of the box.
I like the 330 and the 425. They are "odd ball" engines in everybody's eyes, but still make a lot of power if built right, just like a 350 or 455. Plus they fall into that 1964-1990 all exteranlly the same statement, but the 64 330 has the timing tab on the wrong side.
The trick is finding overbore pistons for the 330. I can't find them anywhere
Redog is offline
Old November 23rd, 2011, 07:16 PM
optimus's Avatar
330 rebuild
ok so there were 2 different 330 or is the 330 a high compression motor and how do i tell if it is a high compression 330
optimus is offline
Old November 24th, 2011, 11:23 AM
Generally the Hi-comp came with a factory 4V carb. Basically you need to consider what you want out of your car. Originality, performance, or what are you after? Then you need to consider your budget. How much are you going to spend?
oldcutlass is online now
Old November 24th, 2011, 11:59 AM
Old School Olds
tru-blue 442's Avatar
Just my .02. I had a 67 cutlass with the # 4 heads and a 4-speed
with a 4 bbl from an old toronado. Damn, that thing would haul...
tru-blue 442 is offline
Old November 27th, 2011, 04:18 PM
goatwgn's Avatar
330's are good engines. You might actually have to lower the CR a little bit (to about 9.2 to one) to use pump gas. My Stepdad had a '65 F85 with a "built" 330 back in the late '60s/early '70s that ran 12's consistently.
goatwgn is offline
Old November 28th, 2011, 06:58 AM
Have you tried EGGE for the pistons?? L2228-8 - PISTON SET
http://www.egge.com/site/?d=48&dt=1&...SMOBILE&rpp=10
Old November 28th, 2011, 05:42 PM
optimus's Avatar
330 rebuild
are those pistons pretty good then i have never used that manufacture
optimus is offline
Old November 29th, 2011, 06:44 AM
Others have used them with no real problems. There may be other venders, just wait and some of the others will chime in. The 330 can be bored up to .060 over, ask your machine shop if they have any sources.
Old November 29th, 2011, 10:26 PM
Redog's Avatar
High compression 330 will have "WG" on the rim of the head
Redog is offline
Old November 30th, 2011, 09:14 AM
Boldsmobile's Avatar
What year 330?
Boldsmobile is offline
Old November 30th, 2011, 09:51 AM
I believe his is a early 67! We never verified what engine is in it from his newbie post. He has an F-85.
jensenracing77
January 12th, 2016 02:02 PM
442dreamer
August 23rd, 2011 07:28 AM
Gary's 2 442-S
August 14th, 2011 12:04 PM
442oldslawyer
April 29th, 2010 09:22 PM
jessejames
March 20th, 2009 08:01 PM
Quick Reply: 330 rebuild
